Metric Drill Bit Sets
swgray
maryland
http://www.mcmaster.com/
High-Speed Steel Drill Bit
Bright Finish 118° Point Not Rated 30555A66 $73.66 per Set
Black Oxide 118° Point Manufactured to DIN Length Specifications 2788A13 $98.62 per Set
Gold Nitro-Carburized Finish with Black Oxide Flutes 135° Split Point Not Rated 30155A57 $107.48 per Set
Cobalt Steel Drill Bit
Bright Finish 135° Split Point National Aerospace Standards (NAS) 27945A27 $148.32 per Set
Uncle Buck
Kansas
I considered buying a set of metric years ago, then decided I really had no need for them. I have sets of number, letter, and fractional up to 1"
Out of curiosity, why would you need a metric set? Can't you do what you need to do with fractional, or is it like it was with me, you just wanted them!
D
dink
Plainfield, IN
Well I turn pens and alot of pens require metric bits...so that is why I need the drill bits...I have a couple brad point metric bits already
Uncle Buck
Kansas
Well, your reason sounds a whole lot better than my reason was! You have a logical reason and practical application! :thumbup:
RPH
Michigan Thumb
Just bought a set while in Canada the other week. NAPA Autoparts was the supply house in town and needed 8mm heli-coil inserts. 39.99 for inserts and 39.99 for the set of British made 2 tone drill bits 1mm - 13mm. Ya, we turn pens too! Sometimes it's good to have a another country close.
MarkH
Kansas
Have usually gotten mine of Ebay. Actually shipped from England or Australia, the last sets were made in Germany and New Zealand. Have not had any problems, but you will need the 25 piece set to get up to 13mm.
