I think ive made a cheap cordless weed wacker outperform basically everything
Junker
New Brunswick
Seems to be the case. Have a Radley (home hardware) 40v trimmer, it was okay. I used an ego 56v and decided to see if blah blah
There was a current choke, couple ferrite rings, I removed them and there was a huge performance boost. Then I was concerned about them actually having a purpose beyond fcc ******** so I added a big starting capacitor from an old AC unit or something and the effect seems to be a much smoother operation entirely. I then modified the head to take 0.095 square line (I used a utility knife and embiggened the hole).
Long story short I can bury this thing in tall wet brush that a lawnmower couldn't handle and it doesn't even bog down.
No pics because it's literally as simple as that. Battery>switch>cap>motor>
^---- <cap <----------
Also the battery life seems to have doubled
Is it really that easy?
WildBill
PNW
Now use a braided steel cable from inside a throttle or bike shift/brake cable for line. Just don't hit your shin with it.
Spareparts
Lansing Ks.
Metal cable in a weed eater, 1975, Irving Texas. The city had weedeaters, put the cables on them, no wasted time replacing the string
worked good until the worker comp claims started popping up. Metal pieces embedded in legs, torsos, and eye injuries. Only lasted a couple months. All the PPE they had to wear made that job unbearable, went back to string.
PCustoms
VT
So you are that guy my brother claims was killed by big oil to keep him quiet!! 🤪
Shhhh....I've been in whitness protection.
Better create a new username now....
  • Haha
Reactions: RTM
PCustoms
VT
I bet if you use this to weedwack Tesla's grave, you don't even need the battery
