Do you get the Enduro Flex or the Enduro Flex Turbo?Yes. Theyre my brand. Theyre awesome. Walter is based in Montreal.
Plain old Enduro Flex.Do you get the Enduro Flex or the Enduro Flex Turbo?
Which grit do you run scooby?
Is this the correct type of backup pad for that Cubitron 982CX fiber disc?The most course. 36 or 40.
Lately Ive flipped over to using the 3m Cubitron 982cx fibre disc in 36 to do the heavy cutting and those things are the cats ***. With a softish backing plate they will do 90% what a flap wheel does, faster, for 1/8 the cost. If something needs that extra "polish" I put on a flapper for the last bit.
Consider getting setup with the cubitrons and saving the expensive Enduroflex for fine finish work. The only place the cubirton fibre disc falls short is if youre in a spot where you can catch the edge of the backing plate on something sharp, for that EF and old fashioned stone wheels are needed, but on the flat its cubitron fibre all the way.
Its "A" type. I have those. Theyre quite rigid (stiff plastic). No backing rubber. No cooling fins.
Also have these made by Mercer, softer rubber backer . Cooling fins. I prefer these for blending and general purpose. Its what I use most times Dont gouge as much. Im sure there are other brands out there. 3m likely has one simular.
There are also very soft ones for blending. I have a Snapon one. You cant put much pressure down at all with it. Usually I use this one to blend tack welds around patches in sheet metal.
Walter makes backing pads of various stiffnesses too. They also make a grinding disc thats supposed to be the match to Cubitron, but I havent tried it yet.
ok you got me confused now because the Cubitron fiber disc you posted shows a Roloc type " TN " quick change disc in 5 inch.
I'm going all over the internet trying to figure how to attach a 5 inch Cubitron 982CX Roloc disc to my 5/8-11 right angle grinder.
I found that 3M backup pad I posted, but it's only coming in 4-1/2 inch.
"How is scooby mounting a 5 inch Roloc disc?" , I thought.
I've tried the Cubitron 982C brown disc in 36 grit with the 7/8 hole, but when I take it off the backing pad and let it sit out overnight, it curls up into a taco shell and is a ***** to get back on using the flange nut. When I saw your link with the Roloc disc, I thought that might be the hot ticket because it would be a press-n-turn instead having to fight that taco shaped disc with the 7/8 hole and the threaded flange nut.
AND the 982C is available, in Roloc, up to 4"
Yes I knew that. I can deal with the TR, TS, and TN mounting systems, but what I can't deal with are their backup pads. 3M is very mirky and foggy when it comes to their backup pads. I swear to you man, researching 3M abrasives is the hardest thing I've ever done on the internet. It's a deep dark rabbit hole that goes on forever with no end in sight.Sorry. Just to confuse things, did you know there were at least 3 styles of Roloc connector from 3M, TR, TS, and TSMAND the 982C is available, in Roloc, up to 4"
The 3m 56573 backer is ONLY available in 4.5". If you want to go larger (or get different softness) from 3m, you need to buy the 5/8-11 hub and whatever stiffness and diameter of backer you want as seperate pieces ! (Yay 3m).
This should be a 4.5 TN https://www.3mcanada.ca/3M/en_CA/p/d/v101239049/
5" https://www.3mcanada.ca/3M/en_CA/p/d/v101239002/
7" https://www.3mcanada.ca/3M/en_CA/p/d/v101239012/
Yeah I want something that I can use the entire surface with. The one good thing about a type 27 flap disc is it's easy to use the entire surface because the center nut is recessed way up there out of the way.Once you've tried a decent 36 grit fibre disc, it's a hard sell to go back to flap wheels. I love Walter flap wheels, and I have a sleeve of them, that have sat untouched since I started running VSM or 3m fibre discs.
So much cheaper & last a very long time. Of course if you're only using the edge of it, it will dull like anything would. If I have a lot of sharp edges I'll run a regular grinding wheel to get them half smooth then fibre disc for basically everything else.
I've got a 4-1/2 inch 3-piece 3M backer setup. I've used it for the few Cubitron discs that I've tried. It's the kind with the nut for the 7/8 hole.
It works ok but the nut is not deep enough for my Bosch grinder. I got the deepest nut they make and it's still not deep enough.
It's made for their own brand of pneumatic grinders I think.
This is what I have :Are you talking about 051141-28476-7 Hub + 051144-13325-3 Pad + 051111-51047-6 Nut ?
Yes, sometimes the stackup makes things tight, I alluded to this above. The one nice thing about the TN mount is it only needs about 1 or 2 exposed threads to tighten on, and you dont need a 051111-51047-6 Nut like you would with a standard disc with a mounting hole.
If you have the upper thick washer as used with a stone wheel, you can remove this to get a little more thread on the 5/8 arbour.
This style(not specifically Walter) is all I ever use with the regular fibre discs with a hole.
How stiff is that orange backing pad? Is it in between the stiffness of the white pad and the black pad?This style(not specifically Walter) is all I ever use with the regular fibre discs with a hole.
Walter Surface Technologies 15D044 Backing Pad Assembly. Abrasive Wheel Pads https://a.co/d/05rSb6ZC
I've only used the orange Walter and a black Bosch I believe is what I have on now. Walter was more plastic and Bosch is more rubber. I think the backing pad is less important then the discs, within reason.How stiff is that orange backing pad? Is it in between the stiffness of the white pad and the black pad?
To me, 100% yes. Those Cubitrons are something special IMHO. Bear in mind, that they do have limitations when grinding into tight corners or where there is a sharp edge to hook on the backing pad, other than that, no complaints, and they definitely cut faster than the EnduroFlex I have.Hey scooby - Before I order the 3M short shaft adapter, are you sure sanding discs are better than flap wheels for grinding down welds flush?
The ones he gave me are even more badasser than yours...LXCam gave me some Walters and they're badass!
The ones he gave me are even more badasser than yours...![]()
