superduty1
- Joined
- Aug 5, 2011
- Messages
- 234
I would like to set up an anchor point on the ceiling with a pulley so I can lift and store the shell from my truck. How much weight can I safely lift/store from my ceiling? I have put a red circle in the area where the anchor point would need to be. I don't think it matters, but the spot in the center of the garage that was designed for an FAU is empty - FAU was installed elsewhere. I know ceiling cords are typically not designed to hold much weight. I was thinking span a few trusses (perpendicular direction) with a 2x6, then use some bolts that went from the 2x6 (sitting above the ceiling cords) to a piece of angle iron on the drywall ceiling (garage is finished). Essentially sandwiching a few ceiling cords. Hopefully that makes sense.
