MushCreek
I've been trying to cast a brass plaque for my rowboat. I say 'trying', because it's been mostly failure, although the last try (number 4) might be good enough. If nothing else, I'm running out of materials. I have a small old heat treating oven which supposedly goes up to about 2000 F., but the temp gauge doesn't work. I bought a small clay/graphite crucible which just barely fits. I cut up a bunch of old brass rod to melt. I made the mold out of wood and little plastic letters. The frame is also wood (bad idea). I screw the mold on, ram casting sand in there, then screw the back on. Carefully remove the mold, leaving the sand ready to cast. I earned the hard way that the mold is supposed to be hot (1100 F.), but I have no way of heating it that hot even if the wood frame did stand up to the heat (it won't). Wood supposedly combusts at about 500 F., so I preheated it as hot as I dared in a small toaster oven.
After 4 tries, this is about as good as I can get it. The heat treat oven has a broken element, which I patched by running a screw into it, and it tends to break each time I fire it up. I don't think the sand is quite hot enough, as the letters don't want to fill completely. As it is, it looks old-timey, like it was dredged up out of the ocean after 100 years, so it has the patina that I want (or am going to have to live with). The blank raised pad is going to have my name and the year I built the boat as soon as I can find someone to engrave it. I want deep engraving, not the wimpy little scratches that trophy shops do.
The mold is gray/black because I dusted it with powdered graphite to help it release from the sand.
