2 sheets bullet proof glass
John McCullough
I have 2 sheets,came out a bank .1in3/4 thick ,teller hole cutt out.Wat n da hell can i do with it to make it disarible,kewl,and usefull !
PBCampbell
WV
I think that stuff is uncuttable, so you are probably stuck working with whatever dimensions you have. If you have a glass supplier near you that actually makes that type of glass you may be able to sell it to them, but no promises.
loganb
Omaha, NE
Laminated glass which is what bullet resistant glazing is(just with multiple laminate layers) is generally cut with a waterjet
liliysdad
Local police and fire departments would likely love to have that stuff for training. We had several sheets we would use for ballistics testing, breaching training, etc.
johnre
Portland, OR
Bullet-proof glass with a hole cut out of it?
When I've seen it used in branches, the hole mounts a two-way electronic communication system so the teller and customer can communicate. I presume it, like the glass, is likewise rated for some resistance to penetration.
BrandonV
Arizona
Yup. I used to install these. They have inserts for NIJ level 2 all the way to level 4 protection.
Usually if the bank was cheap they just do that thing where they put a second larger piece over the hole with a small airgap to allow sound to pass.
