Bigblue&Goldie
I can give a shout out to Sonny's Upholstery in Tempe; they did a nice job on my truck recently.
I did see something similar for sale, and considered using one of the spare sprayer I have. But I ended up buying a 12V pump. Have the wiring sorted out, I'm able to use the high current charge lines. Cut the battery clamps off the pump and put on a SAE 2 pin and it all plugs together nicely. Just need some fittings to adapter to 1/4 hose.For changing the oil in your out drive get a cheap bug/roundup sprayer, the kind with a hand pump on top. Just remove the sprayer tip and put a rubber blowgun tip on it. Makes it pretty simple to pump the oil in from the bottom up. We had metal sprayers converted over to do this, but I think a garden sprayer will hold up for home use.
'Oil change required' message was on in wife's explorer so maintenance time again. Racked, drained, filter swap, refill, clean up all in 40 min. No spills of spatters. I think that is a 1st.
Poked around a bit. Time for air filter. Just put 4 new tires on. 54k. Daughter car is next. Never stops.
Friend rate is free with inclusion of 6-pack.man Justin!! I am afraid to ask what your going rate is to be a friend!!!although it would be worth every "penny".... now if only we could dress you up a bit with a....... "bowtie"!!!! DDOOOHHH!!
Thanks Zip! What?That's pretty sick Justin! Wish I could be there to hear it, but looks like I may not hear anything afterwards!
I had considered putting LED strips in the ports for indirect lighting. Might do it like you sugested.I vote for red LEDs inside the ports near the tips, but not visible unless almost directly underneath them.
And a fogging machine that will occasionally discharge thru the ports would be a bonus!
Well the good thing is I am in control of the volume, unlike a concert.I knew I should have invested in Miracle Ear back when these systems started thumping and a bumping! I’d be RICH!!!
Sounds about right! I usually make more of a mess with the waste oil/lube than I do doing the entire job. I like the pump, I have one I made for oil changes on our boat, I just use a hand pump for the outdrive.Boat outdrive oil change went OK. The pump was able to handle the 90w. Got warm but wiring and whatnot good enough. I did manage to spill some waste oil trying to open the shop door with hands full, but I guess that's just part of the process.
Yes I utilized those itemsSounds like it's time for a cold beer or two and some tunes...
Are you using the pump to pull the oil out? I have a 7 qt Vac pump/container that works pretty well. Can use air instead of armstrong power.Sounds about right! I usually make more of a mess with the waste oil/lube than I do doing the entire job. I like the pump, I have one I made for oil changes on our boat, I just use a hand pump for the outdrive.
It's an integral part of the speed metal experience.yes, however the power supply is internal to the 4' T8 style LED tube, and there are 44 of them. I guess disco lights is just part of having a ridiculously high powered audio system.
I used the stainless marine pump that HF sells(I’m not sure if they still do). I added a 90* rv water adapter turned down into the top for a 2.5-5 gal bucket. It screws into the dipstick and works very good.Are you using the pump to pull the oil out? I have a 7 qt Vac pump/container that works pretty well. Can use air instead of armstrong power.
