Clamp storage - let's see your ideas, pics please.
TheGrooveking
An alternate reality in a parallel universe.
In trying to better organize my C-clamps and bar clamps I wanted to tap the collective around here to pickup on some ideas before I do mine. With having about 24 bar clamps and over 40 C-clamps from 16" down, I need a easy/accessible way to store them. The C-clamps have been jammed into multiple tool cabinet drawers which could be better used. So please post pics if you've got them so I can maybe borrow your ideas...
TheGrooveking
meissen
Macomb, MI
I think a variation Breeze's idea is going to be the best with 40+ clamps. Maybe a dowel rod made out of a pvc (or steel, depending on weight of the clamps) and mounting it off the wall a few inches to allow the mouth of the clamp to slide over it.
kartracer23
New Castle, IN
I don't have a pic, but I just use a couple of pieces an angle iron (1" x 1")mounted to the wall with screws. Holds quick clamps, pipe clamps, C-Clamps and squeeze clamps. I put the squeeze clamps & smaller C-clamps on the top one, and the longer clamps on the bottom one.
JC23
Northcoast
That can't be Breeze's shop, it's TOO CLEAN! haha
Here's mine but with a disclaimer. It's for my smaller ones. I fastened an old high rise SBC valve cover to the top cover of my drill press and loaded it up! Granted, most of them are plastic but for that use, this works great and takes advantage of normally wasted space. The drill is next to my main bench and vise so the clamps are close at hand!
I am in the deep thought stage about a cart for my welder and plasma that will use the principals of Jack's folding welding area. And that's where the metal ones will reside.
Jack Olsen
Los Angeles
I store my bigger ones on L-brackets screwed to a piece of plywood.
I also have some on the wall behind my fold-down welding table.
gbick
I'm assuming you don't change your spindle speed very often.
41 Dave
Adelanto, Ca
Jack, You are 'da man for maximum use of the space you have for work areas and storage. You have the "Porsche" of all storage/garages !
41 Dave
LesserSon
PA USA
There are a LOT of clamp storage threads. Rather than start a new one, I’m just going to put this idea for STANLEY No404 picture frame clamps on THIS old thread, for posterity.
IMG_2351.jpegI have a lot 404s - twenty-three (twenty-seven if you count Oxwall knock-offs). Once, I was trying to glue up multiple frames with limited time, and I just didn’t have enough. I’ve been buying them at yard sales and flea markets onesie-twosie when they are cheap ever since. I use them when I need them, which isn’t often. The rest of the time, they’re tossed in a drawer with C-clamps, Vise-grips, bar clamps, etc. It was a jumbled, frustrating mess.
No more.
Today, I took some 2”x3/4” scrap and crosscut 45° notches every 1-1/8” along one corner of their length, using a cradle/sled on a tablesaw. The notches should really be at 1-1/16” intervals, but I was eyeballing the cuts and making two passes with a thin blade, since this is a one-off project. With a spacing jig and a wider, single-pass kerf, 1” intervals might work. Packed tight, the 404s help support each other when the drawer is opened/closed. IMG_2352.jpeg
I considered making two parallel runs, which would hold up to thirty-six 404s in this 14”x21” drawer, but I didn’t like how restricting the narrow space in the center would be, so I settled on a configuration for twenty-six. All this was a consequence of the dimensions of the drawer - multiples of four would be more logical. IMG_2355.jpeg
This drawer is 10” deep - 9” would be the minimum to close with 404s on end like this. I think with some adaptation to the notchiing, other types of clamps could be packed into drawers or boxes in a similar way.
Spareparts
Lansing Ks.
A friend of mine had a fab shop and I think he had the neatest rack for holding bar type clamps, all it was is a
piece of 3" X 4" X 1/8" angle. The 3" side was anchored to the wall the 4" side was drilled for the dia. of the pipe
and slotted to be able to slide the pipe into the slot. Most clamps were 3/4" pipe maybe 20 with some 1/2" maybe
6. That was about as simple as you can get while being quiet handy.
Ultradog MN
Twin Cities
TheGrooveking
niget2002
Josephine, TX
I don't have a good picture of mine, but you can see it in the right side of this picture. It's on a rolling cart. The other side of the cart has scrap wood storage. I just made L shaped brackets screwed to the vertical plywood. There's a shelf on the bottom for odds and ends clamps that won't sit on an 'L'.
Man this picture is old... so much has changed since I took it.
lilredex
Toronto
Some of my ideas.
lilscorpion
Colorado
Got a thread where you’ve documented? Curious as to how you’ve done some things unanticipated you had to deal with. 🍺
phred
NC
Nothing fancy, just simple and out of the way.
Jgaz
Masonite glued on top of the 2x4 to add a bit of strength.
Some plywood cutoffs and cross dowel hardware that was left over when I downsized my router table.
cosmokenney
Loyalton, CA
I have three main locations for clamps:
When I originally build this welder cart, I added this open shelf for brushes and clamps.
But then quickly acquired too many clamps and got tired of pulling them ALL out in order to get the one I needed. So now I have seldom used clamps and brushes in there.
Then pulled all the C style clamps out and hung them under my welding table.
And all my spring/pony clamps and similar are clamped to a shelf along with all my hand rests and some other items.
whateg01
doo dah, kansas, usa
I really dislike the racks that require you to tighten it loosen the clamp to hang or remove it. Often I'm holding something in place with one hand and clamping with the other and realize I need one more clamp. I want to just grab the clamp and apply it with the one free hand. The exception, of course, is the big clothespins.
TurnipTruck
Southcentral Alaska
I salvaged some 3/4 rigid conduit and old cast iron receptacle boxes from the dumpster and welded it all under the weld table to reduce tripping on extension cords, but it turned out to be a great place for clamps, too.
I have since added some big cleats for all the weld leads and painted the legs, but it’s still a disorganized mess underneath.
niget2002
Josephine, TX
A-ha! I found a better picture of mine. This happened to pop up on my FB 'memories' today. There's been quite a few more clamps added since this picture was taken. The bottom trough is used for odd shaped clamps and my band clamps.
gahrajmahal
Cincinnati, Ohio
I made a small stand so I could mount my vise close to the door and also securely attach the whole thing to the house. The base is covered with brackets that allow me to store my clamps.
I especially like the “French cleat” wood brackets that allow me to grab all my quick grip clamps and take them to the location I am working.
LeeG
Phoenix, AZ
I built a wall mounted cabinet. The doors are also cabinets.
Closed:
Open:
The parallel clamps on the right range in size from 24" - 60" with 4 in each of the holder, and a row of 12" on the bottom. The left side is mostly bar clamps from 6" - 36". Inside I have my pipe clamps, c-clamps, corner clamps, and overflow parallel clamps. I have 200+ clamps in a 4' wide by 1' space.
My welding clamps go in slots cut in my cutoff rack.
Lee
NakeDiesel
oklahoma
Not the best pic, but I used what I think are bicycle wall mounts or tool mounts that I found to put all my clamps hanging on.
ALinCarolina
NC Piedmont
i picked up a stainless cart at the junkyard and made it into a clamp cart. It was originally in a restaurant kitchen for trays. The back side is set up to hold parallel clamps. IMG_4504 2.jpeg
Gutman
ENC
Braver man than I to have what appears to be a glass top as a benchtop.
ALinCarolina
NC Piedmont
That is my assembly table. Works great since it is very flat and I apply wax to it so any glue that gets on it pops right off. The woodworking benches are wood. The autoshop has stainless steel and a nitride coated welding table.
