JackOfDiamonds
Because I have no man-door and no place to put one (garage is surrounded by housing on all sides), I use my roll-up door a lot.
This doesn't really bother me because the garage opener is convenient and hands-free, and I don't mind the wear and tear because I want the garage door opener to break so I can replace it anyway. But every time I do this it lets in a wave of 105F heat, or -10F cold in the winter. Plus, with me always opening the door, it means my nosy neighbors get a clear view to see inside and whatever I might be doing in there.
My idea is put up a strip curtain all the way across, about 12 feet, and as high up against the door track as possible. Then the door will roll up over it. It won't be a perfect seal, but it should be a lot better than a 12x6 opening, and while I'm carrying stuff in and out it should block drafts and be a privacy screen.
This is the outfit I'm looking to buy from but I don't know whether to get 6, 8, or 12 inch strips, or how much to overlap them. I don't want to have to force my way through them, but if they are too flimsy and flutter around like streamers in a slight breeze, they won't do the job. Has anyone done this?
plasticstripcurtain.com
Economy Plastic Strip Door Curtains - Complete Kit - Ready to Install
Plastic Strip Door Curtains are the Ideal Solution for Preventing dust, cold air and noise from moving between separated areas. Our Strip Curtain Kit is made from the Highest Quality PVC/Vinyl Strip Material right here in the USA. We recommend you order your Strip Door Kit a little longer than...
