Tig water chiller coolant?
no704
So this topic seems as old as chicken or the egg.. got a new chiller and an induction heater, as opposed to a tig torch. Will likely be used for tig also in the future.
Seen every angle on what coolent to run. Just got it set up today with 100% distilled water. See lots running automotive coolant, special welder coolant, tap water, window washer fluid…etc.
opinions?
Jswain
Calgary, AB
My Lincoln chiller says right on it use automotive style coolant if temps go below freezing, or distilled water if they don't.
Some will be different though, so go by what yours calls for
N
no704
Manual calls for distilled water, that’s what is in it now. Below some temp it calls for organic coolant. In Phx it will never see freezing temperatures. I tend to overthink these things.
At a past job we had a fog chamber that was filled with DI water and rotted out the evaporator in a couple years. Not on my watch!
Was a $80k machine. Wade tee would not cover it. Too high dissolved solids by a lot. Was able to repair it and switch to only distilled on that one.
turner66
Texas
I use Miller coolant in my Miller Coolmate cooler and the manufacturer recommended Cantesco coolant in my Primeweld Maxcool cooler. Most importantly they include algae and corrosion inhibitors...
bdbecker
Iowa
...Most importantly they include algae and corrosion inhibitors...
+1
It's worth putting some coolant in there if for no other reason than to prevent algae growth. I've flushed out a few neglected chillers over the years and it is downright nasty what grows inside of them. If OP wants to run straight water, it's worth flushing it out at least annually, if not more frequently.
turner66
Texas
"If OP wants to run straight water, it's worth flushing it out at least annually, if not more frequently."
Right on! I'd be in favor of much more frequently even.
It's the wrong place to try and "save a few bucks" .
The cost of maintaining even the cheapest Miller Coolmate is worth every penny of the $50/gal Miller coolant when you figure the cost over time. Cantesco for the Primeweld cooler is only $20/gal.
N
no704
Running straight distilled now. I’ll throw in a bottle of coolant. Company cc got hacked so when that’s straightened out I’ll throw some on the next McMaster order.
dffay
I use De-ionized water. Gallon jugs from the grocery store availability.
