Another Vice rescue...
PDXDave
Pulled this one from a crate of junk that got dropped off today.
Haven't researched it at all yet, figured I'd give her a bath first.
P
PDXDave
I fear this one is taking a nice, long dip in the apple cider vinegar....
She's crusty.
john.k
Screw looks past rescuing ..........probably a standard acme thread ,and the handle and outer part wernt submerged in dirt,fortunately.
It's 90% dirt
I've already knocked a ton of it out.
Forget which thread I heard this on, but good, old style jute twine makes a great dental floss for the teeth on big vise threads. Wrap it around and pull tight, spin the handle. Add a solvent if greasy.
Works for any big thread, did my drill press vise a few weeks back, and a 6” C clamp last weekend.
john.k
I just rescued a more modern vice with the screw rusted out .........in fact its the most modern vice I have...........fortunately ,the correct screw was fitted to several models ,and I was lucky enough to see a part-out of a smaller vice with the same screw on FB ..........the screw is available new ,but an exorbitant price.
1982fxr
Phoenix
I've tried lots of methods over the years for cleaning old vise parts, dried grease on leadscrews, etc.
In the end I just got another bench grinder, took the guards off and mounted a sacrificial wire wheel for like $8. I'd never go back.
autobon7
Don't have access to it anymore (different job) but I prefer to sandblast. Fastest and most thorough method I've tried so far.
1982fxr
Phoenix
I had that. Between buying all the ****, the compressor, the less than ideal set up at home, never again.
Now if I had access to one at work...all day long and 8 days a week.
john.k
I had free access to a grit blasting setup ...........they used to do a railway wagon in an hour.............i did other peoples stuff for them ,never my own ..........then I quit all of a sudden..........no more free blasting...............I got diesel compressors that dont work,a Clemco blast pot that needs 100cfm to work,...........but most of all ,very sensitive neighbours since I last blasted in the back yard maybe 40 years ago.
john.k
If I had to derust that screw ,I have a go at flame spalling ........getting the screw out of the nut may be a bit tricky too .
