Vintage Snap-On tool box
Rod N
Keswick, Ontario
This came up 10 minutes away for $80. Couldn’t resist.
To what stage do I clean it up?
First need a key cause when you tilt it to put in the front car seat all the drawers slide out.
Beerhippie
Far NE Oregon
That's almost identical to my red "mystery box"--the closest I've seen yet. Only difference is mine has a tote for the upper tray.
As for your questions: How far to take it is purely a matter of personal taste. How to keep the drawers from sliding out when tipped? Tip it with the drawers up.
J.A.F.E.
Formerly Area 49 now Area 52
Nice score!
I'd leave it alone - it's only original once. Clean it and a little wax. It also has the drawer removing tools usually they get lost.
Take the lock out and a locksmith should be able to make a key. The lock was made by Fort and the blank for that one is probably an Ilco 1527. If there's a number stamped on the face of the lock there's online places that will make a key - assuming it has not been rekeyed at some point.
R
Rod N
Keswick, Ontario
It actually looks better in real life.
I took all the mats and drawers out to give it a good clean and the seller had beat me to it.
Bonus it came with original paper work.
I'll see if I can fix the dents, but I'm not going to paint. Wax? Snap On docs.jpgMade in Canada.jpg
VR6ix
Onterrible, Canuckistan
I used a basic 3-step automotive clean/polish/wax after a healthy cleaning and de-greasing of everything, brings back a nice deep gloss. Just tap-out the dents and dings that bug you and go to town cleaning it. Use wax or a wax-based lube on the slides, not oils or grease.
Really take time to inspect and straighten all the sliders themselves and the channels they ride in on both the drawers and in the main cabinet.
Lookin4'67Galaxieconv
Atlanta, GA
I like to do a light wet sanding with 3000 grit paper, then dry and wax. I'd give the slides an evaporust bath, then lube and re-use, as long as they're usable.
R
Rod N
Keswick, Ontario
Those tools in pic #6 slide in the gap with the drawer partially open ,then pull out.
Directions should be in the paperwork under them.
I used the tools to get the drawers out, but couldn't get them to release the slides.
jetlag
Centralia,Wa
I dig that box. I'd be tempted to give it the "rat rod patina" treatment and put a 2k matte clearcoat over the original paint, just to protect what's left.
