trexmonkey
- Joined
- Jul 17, 2024
- Messages
- 5
Ok so its a belt drive, with a 1.5hp marathon motor on it. The power plug, 1 of the prongs has the very tip burnt off. Could just be people plugging it in while its already turned on.
Anyways i just got the compressor used so i have no idea if it would have normally ran on my garage outlet without problems.
When turned out it seems to run fine, until it hits about 60 to 80 psi, then it blows the house breaker.
What ive tried:
I blew the motor out with compressed air, it was pretty dusty. No change
I took the check valve out, took it apart, not sure if theres supposed to be any kind of rubber gasket in there or not? Couldnt find one anyway. I thought maybe the spring was a little soft so i put a stronger spring in and put it back together. No change.
Edit: oh and i ran it with the drain open and it ran for over 5 mins, didnt blow the breaker, so i turned it off.
So now im here, any ideas
What ive tried:
