Greatwhitewing
- Joined
- Nov 20, 2011
- Messages
- 531
Have a covered but otherwise open deck in New England area with a good quality Epson projector and a screen. Want to build a PVC enclosure to house the projector for a few months a year to provide second level rain/condensation protection and a level of security while allowing projection and removal for inclimate weather months. Enclosure to remain in place all year.
I have 1x10 PVC boards (3/4 x 9.5 actual) and PVC bead board material panels around 1/2" thick with enough 3/4" for top, bottom and rear panels and use the bead board for side panels to match deck design (nice PCV/Composite deck). Not sure yet what to use for removable front panel to allow projection and cooling air flow but probably have a gasket and over center tension latches.
Projector dims are about 13.5" deep plus rear connectors X 16" wide (plus fan air) X 6" high min (probably more like 8-9") to allow cable storage. Probably get a right angle HDMI connector to minimize enclosure depth
Currently mounting projector directly to an adjustable tilting bracket I would use to mount the enclosure.
My primary question is about joint detail and what adhesive to use. I will need edge joining also since my 3/4" boards are not wide enough. I have used PL-300 in the past but it's quite messy.
Thanks in advance for your learned advice
