Cool! You have same name there? I'll look ya up.I follow your VW build thread on Vortex lol.
It runs perfect all day, other than the random long cold start, so I didn’t do a compression test. I did one about a year ago when the spider injector initially failed, it had a dead #1 which replacing the spider injector fixed.What's the voltage? Have you done a compression test?
I didn't check the voltage because it cranks over like a champ. If it was even border line, it would never crank as long as it needs to during the long cold starts. Some of them were a good thirty seconds of cranking. I wouldn’t just crank it for 30 seconds straight, but over all, it was about 30 seconds sometimes. Never even slowed down.
It’s gonna be a few days before I can get to changing the injector, but I’ll for sure report in.I'm having the same problem with an 05 suburban. I've changed the cam sensor and fuel pump. Fires right up when driven and shut off. But it will not start on the first try after it's parked for awhile. I actually kind of hear a small backfire at the end of the dead crank. Let us know if you figure this out, and I will do the same!
I have always been tempted to put filters on the incoming air. But rain, moisture, and general inertia...
My daughters window shaker air conditioner had some mould visible so I took it apart to clean it, I could not believe the amount of dirt and sludge that was in there, disgusting and this is only the second year she’s had it. So guess what’s now on my annual list of things to do? You guessed it, take apart and clean our 3 air conditioners.
Maybe mount it at more of an angle? Seems like water is pooling.
I put filters on the return air of the HVAC system,I have always been tempted to put filters on the incoming air. But raon, moosture, and general inertia...
Kinda, I go by Mr.Pink1942 over there.Cool! You have same name there? I'll look ya up.
Just been small updates, maintenance. It gets driven. Have a thread on the 2dr Jetta too, but that one has to be 17yrs old now. Still have the car and drive it occasionally.
For ac units, it is quite a hassle to filter the outside air. Heat, air flow, moisture (rain, humidity, condensation), and space.I put filters on the return air of the HVAC system,
but no build thread on the Korrado loland I go by, well... the same name.
Scary how easily and quickly junk accumulates in a small garage!
Or any flat surface!Or in a big one...
Going somewhat off the wail for a newer computerized engine: have you checked the plugs and the timing?I didn't check the voltage because it cranks over like a champ.
I'd not thought about your solution, but that would have worked. Nice thing about using the banjo bolt is I'll keep it on hand and have it for the next time I run into this issue.I like the modified banjo bolt. I might have bolted that rear master to one of the front caliper lines to push that piston out, but then I would have needed to re bleed the front caliper. Probably less work the way you did it.
I should probably nuke both of my fiberglass ladders because they are faded and getting hairy. And I don't really want to climb to the top of any ladder as long as those. But I'm still good with my antique short steel ladder that is similar to the one from your MIL. Steel has lots of really nice properties for a small ladder. As long as it isn't rusting away, it's probably fine.Philip, I'm the likely the least qualified safety adviser on the GJ but I'd shorten that ladder to something like four feet. A fall from 5 or 6 feet might leave a mark or put a body part in a cast. If that ladder was old when you got it, there's no way of knowing how much UV damage has been done to the fiberglass. The rivets you've replaced is a start but you don't put any weight on those. The rusty rivets that attach the steps to the rails look pretty rusted and those rivets hold your full weight. If a ladder step lets loose it will be a complete surprise and you'll be headed for the ground at a rapidly increasing rate.
Full Disclosure: I have made many mistakes when it comes to ladders. In 1968 (three years before OSHA was born) my tallest ladder was four feet high and had no safety warnings so I used all but the top step to paint our first house with a spray gun. The extension ladder would have been safer but holding a spray gun with a quart of latex paint with an outreached arm was too close to a torture technique my father used to prove how weak I was as a kid.
A decade later (47 years ago) I bought a super cheap 6-foot aluminum step ladder. The skinny leg eventually buckled on me and I landed on a sturdy hedge. No stitches or casts and using logic similar to yours I reinforced the part that buckled. As @niget2002 points out, stainless hardware would have exceeded the cost of the ladder.
I inherited a short stepladder from my mother-in-law and use it all the time. I suspect it's older than my 6-foot POS but I feel really secure standing on it.
It might be a post-OSHA ladder because the thing that looks like a step at the top is neatly engraved with reminders.
Your post triggered me so once again I visited Jeff's River of Stuff. Knowing how poorly my cheap-*** 6-foot aluminum ladder performed and how uncomfortable its narrow steps are on my bare feet, I looked for the most expensive 6-foot ladder Jeff offers. It appears to be very safe and only $232.97 a month for 12 months.
I'm not sure I'll be alive in 12 months and certainly don't want my widow to be stuck with installments (remember, we don't have a mortgage or car payments or credit card balances that include interest charges). I looked for the least expensive 6-foot ladder and rejected the first few for the first "Jeff's River Choice" at $11.67 a month for 12 months. It's on sale so I decided to pay the full price ($69.99 [22% off]) for the reason mentioned above.
I hesitated for a moment before placing my order because the page showed me a 6-step ladder for about double the price. The cheaper one isn't really a 6-foot ladder and it's not even a 6-step ladder. The 6-step that's on sale for just shy of twice the price caught my eye...
... but I immediately rejected this one because -- see first photo -- I would be standing on that 6th step with pneumatic nailer in hand and the box of nails between my feet. The company offering the 6-step ladder is also named WOA WOA (made me think twice).
12.7/14.1What's the voltage?
I did cap, rotor, wires, and plugs a year ago when I replaced the injectors. It runs perfect other than the random long cold start, so I didn’t.Going somewhat off the wail for a newer computerized engine: have you checked the plugs and the timing?
Yeah. That's my backup plan.If not, a racing strip will look great.lol
Try priming the fuel system a couple times before cranking on a cold start.12.7/14.1
Since I am waiting to do the injectors next week, I did a little experiment. I started the truck and let it run for a minute, then when I shut it off I bled off the pressure through the gauge release button to see if it would long start the next morning. It did.
This leads me to believe the issue might be more likely to be a draining issue, rather than a flooding issue.
Tried it the first day, makes no difference. The real strange part is how it will start with 0 psi after sitting all day.Try priming the fuel system a couple times before cranking on a cold start.
Key on 5 seconds, key off, key on 5 s, key off, then key on and crank.
Here's hoping you have better luck than I did. The sparrows built there nest between the spikes.Assembled in the garage this morning...
For some reason, sparrows have decided to roost on a ledge over my front door entrance... Never had this happen before...
Bird droppings have built up on the ledge and I'm constantly cleaning the floor just outside the door...
I decided to take action and bought bird spikes from the jungle site... The package arrived today...
Some assembly required... The spikes assemble in 12" sections... All stainless steel... This should fix the problem...
Birds are inventive, they'll be roosting and nesting right in the middle of those spikes.Assembled in the garage this morning...
