SouthernIllinois
- Joined
- Jan 14, 2024
- Messages
- 1,680
I don’t think it’s made by Eaton/Emax. The guarding is definitely different. But they seemed to of taken inspiration from their intake box styling and running the pump at low speeds for noise reduction.Looks like the Emax compressor. Their better models get pretty good reviews with the silencer.
Just looks like paint and stickersI don’t think it’s made by Eaton/Emax. The guarding is definitely different. But they seemed to of taken inspiration from their intake box styling and running the pump at low speeds for noise reduction.
I have an Eaton without the big intake box and I can talk on the cell right next to it running without the other end hearing it and I can understand them as well.
I just received this compressor and hooked it up to my 3/4" Rapidair system. Volume flow rate was 150% of my old unit and was on sale so I pulled the trigger.
So far I can say it is quite a bit quieter than the 60 gal Kobalt it replaced (and significantly heavier). The pump is an Eaton V with disc valves and the motor is 230 Volt 1750 rpm unit with Airbase Industries Canton Ohio on the label. No idea where it was made. Comes with a 4 year warranty for consumer use.
When I bought my Eaton a friend and I went to canton to pick them up. (He bought one as well)No idea where it was made. Comes with a 4 year warranty for consumer use.
We had a quick walk thru the facility. They make the tanks/pump plates, guarding, and silencers there and assemble them to the pumps, motors, and controls. They obviously don’t make the motors or controls and the pumps were made for them in china.
They have been good compressors for my friend and I. If I remember correctly it we bought in summer of 16.Hmmm, now I see that the Polar Air 5 hp straight from Eaton's website is 20% off for July. Gets it down in the realm of the NorthStar price, but you get a pressurized lube oil system and continuous run option. They also put the pump on risers for better cooling. Even comes with an auto drain valve. Their warranty plan is a little confusing and I can't tell what the shipping cost would be.
