Vintage Blowtorch assembly
boldenz
does anyone know if i am assembling this right
LXCam
No doubt there’s several guys here that will know. But I’ll toss @don long under the bus on this one. His collection and knowledge of rebuilding old equipment is beyond compare.
Beerhippie
Far NE Oregon
Here's how the non-return valve assembly of your C&L goes together:
I'll have to take the pump out of mine to get a pic for you.
Here you go:
The springs on the NRV were broken. I replaced them with the springs that push the flint up in a BIC lighter. I cut the new pip for the NRV from some Viton sheet--70 Duro, 1/16" thick. I use Neat's foot oil for the pump leather.
boldenz
any ideas of what this Dirt is and how i can clean it
Beerhippie
Far NE Oregon
What part is that? Is that the gland that holds the pump shaft in?
The "dirt" appears to be packing--possibly asbestos. Just pick it out under running water in case it is asbestos. If that part is what I think it is, there shouldn't be a packing in there.
If that's the gland (packing) nut for the valve shaft, not only shouldn't it have packing in it--it compresses the packing around the shaft--but it looks like you have a hairline crack in it that needs fixing.
boldenz
its the part that the handle goes into i think
Beerhippie
Far NE Oregon
That's the valve stem packing nut. The handle is the thing at the back you use as a handle.
There should be a tubular graphite packing on the valve stem--the thing that goes through that nut.
boldenz
can u replace the graphite and whats the valve stem suppose to look like
Beerhippie
Far NE Oregon
Hopefully you have it. If not, pretty much any C&L valve stem should fit. Try to find one in better shape than mine!
You can see how I've used Teflon plumber's tape to build up a packing. Graphite was original, but finding one in the correct size might be a challenge.
RPH
Michigan Thumb
Both graphite and Teflon can be bought as a packing material. Diameter of various diameters are available. Check the big box stores for quick pick up.
Beerhippie
Far NE Oregon
I don't mean to be snide here, but this is a device that burns pressurized gasoline. Pressurized gasoline and flames aren't exactly toys.
Please find a good You Tube or such tutorial on how liquid-fueled blow torches work and how to restore one before proceeding with this.
larry4406
Northern Virginia
I have one of these and fear same.
boldenz
i appricate your concern, but im just resrtoring it for display and ot acutually using it as a torch
boldenz
is this brass torch piece suppose to come off to be clean or does it stay on the rod ?
