kaymccampbell
Upstate New York
Tried it the first day, makes no difference. The real strange part is how it will start with 0 psi after sitting all day.
Whats gonna piss me off is if I change the injectors and it still has a cold start issue.lol
99.9% of the time the issue only happens in the morning, but there have been some mornings when the pressure was 0 and it started with no issues. This makes me wonder if there aren’t two separate issues.
I guess I’ll know that after I change the injectors.
If it fails to start on the first go, have you just walked away from it for an hour and then tried again?
Snip's
Birds are inventive, they'll be roosting and nesting right in the middle of those spikes.
Well darn it... Apparently I should have asked about this on GJ before placing my order for the bird spikes...
I mentioned to my wife about the responses from the site...
In about 2 seconds she says... "Just eliminate the ledge and the birds won't have a place to sit"...
Whaaaaaattt???
"Just cap the ledge with an angled piece of wood so the birds slide off the ledge, and the spikes idea won't hurt them"
I feel like a failure...
Wrench97
Southeastern Pa
I still think you should pull them out and test/see if they are leaking first.
Hmmmmm... I may need to wire up a cattle fence zapper... v2.0
Your problem with those spikes si that they were designed for larger birds like pigeons and crows. You need the small bird version
Whaaaaaattt???
Or do this ^^^ Smart lady
Old Man Roger
Palm Coast Florida
I'm having a similar issue cold starting my wife's 2017 Ford Explorer with extended crank before starting...
Not sure if this would apply to your situation...
It's my understanding that with my Ford the ECU won't fire the sparkplugs until proper oil pressure is established...
I suspect my oil pressure sender may be at fault... :dunno:
Mine has spark and fuel pressure while cranking.
No, I always start it.
Oh Im taking your advice for sure, but Im replacing them either way. The warranty runs out on the 10th, if I’m going to have them out, they’re getting replaced. the whole spider injector is under the intake, If they were easy to take out and test, I would have done that as soon as you mentioned it. (y)
FreedomPenguin
This week I organized my garage, and painted my corner I’ve neglected for years. Tried seal Krete 1 part epoxy 2 layers, and then 2 layers of clear coat seal Krete.
Trying to make it all nice! Mopped and organized
nadogail
Coronado, CA
I was called by the tenant who lives where the Heat Pump installation was completed late yesterday afternoon, she reported No Hot Water.
I found that there was no voltage at the Water Heater.
We immediately went to the circuit breaker panel and found that some breakers were turned off. Turned the breakers on, but nothing measured at the water heater. Pulled the Panel Cover and found the conductors for several circuits had been disconnected and cut back. One of which was the feed to the Water Heater.
Extended the existing wiring to a breaker and reconnected. Hot Water has been restored.
The job was further complicated because my van which not been started for a couple of weeks had a Dead Battery, it is now connected to a Battery Charger and I will let the HVAC Contractor know that he will not be paid until he compensates me for his screw up.
Wrench97
Southeastern Pa
Yea I never was a fan of the spider systems, but in todays design world it's not as much work as changing a ign coil on some cars and less work then changing a starter or alternator on others...
Wrench97
Southeastern Pa
Scarier part is what did he leave connected that he was trying to disconnect?
niget2002
Josephine, TX
Holy **** that's some bs. Geez.
KwikFab
Central Valley, CA
What services do you provide otherwise? Where are you located?
I offer welding, fabrication, repair, CNC plasma, and whatever else I can fit in my garage.
Just posted a thread (my first) in the tool section asking about a press brake where I added a few pics of stuff I've done.
I'm just a hobbyist working out of his garage, but happen to make stuff for sale when needed.
Out of Central California.
Metallitubby
ATL OTP North
I envy the look of your finished product.
nadogail
Coronado, CA
No he had very neatly disconnected all the two pole 20 Amp breakers and capped all the cut wires. The problem is he disconnected and cut and capped the feed to the water heater in addition to the feeds to the radiant heaters in the ceiling.
Wrench97
Southeastern Pa
He had to know he disconnected and cut x sets of wires for x number of heaters so unless he thought the HW heater was another radiant heater there may be still be one hooked up?
nadogail
Coronado, CA
I would not have been able to figure out what the trouble was if I had never screwed up a job.
I have screwed up a lot over the years and sometimes remember what I did wrong.
Smart People learn from their mistakes, really smart people learn from the mistakes of others.
Old Man Roger
Palm Coast Florida
Ya, imagine putting a starter under the intake. :wtf: I mean they know it’s a normal wear part, but they still do it.:dunno:
Or how about a headlight that takes 4 hours to change?
Snip's
In the garage today, I finished stripping the house paint off the second porch light at the front entrance...
There was house paint on all the glass panels, that was quickly taken care of by my Simple Green dip tank... Paint fell off completely...
I rebuilt both of the 1940's vintage ceramic light sockets with 16 ga silicone wiring...
Got them both installed and working...
My wife wants them left with the raw copper (exposed solder joints) and all, so they will patina naturally...
kaymccampbell
Upstate New York
Close!
Conversion to shower!
New mud set shower, floor, cabinet, top, etc.
After this one, then the master.
4 adults here; wife and 2 daughters. Had to build a new basement bath before I could take this one off line. No way 4 of us could get by with one bath.
What's wrong with a garden hose in the back yard?
While putting some things away I found another driver with the "chalking" disease on it - pretty bad - This one was not in a drawer, but at the back of a magnetic rack on the side of my bench pretty much out of sight. -Its an old Craftsman PH #2 and in the shape it was in a good candidate for "before" and "After" pics ot my "cure" which is jsut a wipe down with Mineral oil.
Before an initial wipe down, followed immediatly by a more detailed one to get in the nooks and crannies -
I shot the pic and rotated 1/3 for each pic:
And after the described wipe down - Same 3 rotations:
All in all, pretty effortless; Just ordinary mineral oil:
kaymccampbell
Upstate New York
Pics, or it didn't happen!
You'll have to use your imagination. Long before I had a camera, when I acquired my first house, the water pipes to the bathroom were rotted out, so the garden hose on the back patio was something I did for months, til the house was in good enough shape to have actual plumbing installed.
PassnThru
Bowling Green KY
I have a temp gauge in the attached garage with a remote that I keep in the freezer in said garage to monitor the freezer temp. I noticed the other day that it was blank - needs new batteries of course. Yep - little late to the party as they leaked severely. So I took it apart and mixed up some baking soda and water and cleaned what I could and wire brushed the terminals. The negative terminal wire was really bad so I unsoldered it and gave it special attention. Putting things back together I just could not get the negative wire soldered into the terminal - the solder just wouldn't stick. Given that I'm a novice electronics solderer at best it was confusing. I finally figured out that the corrosion had traveled up the wire and that's probably why it wasn't sticking. I cut the wire back until I found shiny wire and spliced in a new wire. Then soldered that wire to the battery connector easily. Pic is of the soldered splice and the old wire - that corrosion can really travel up a wire.
welder4956
Birmingham, AL USA
Took the old engine off the stand, then uncrated the new one and put it on the stand. Then installed the threaded plugs in the unneeded thermactor holes. Started to install the one piece fuel pump eccentric from the old engine and found the dowel in the cam doesn't stick out far enough to engage the eccentric. I swapped in a longer one from a Comp Cams kit, but still not long enough. I can either switch to the two piece eccentric, use a longer dowel from a big block Ford FE motor, or use an electric fuel pump. I need to check the timing cover first to make sure there are no clearance issues.
