KwikFab
Happy to join this forum and learn from the many experienced members here.
Short intro, I'm a disabled veteran, and retired (not from service), just having started my own shop some 3 years ago. Also just got into welding and fabrication 3 years ago so I consider myself new to the hobby still.
Pictures for attention.
My small shop -
Pictures of previous work I've done when I first started welding -
With that said, I've found myself enjoying making a lot of one-off stuff and find that I often have to do bends with precision.
I used to own a Harbor Freight 20 ton press, with Swag OR finger brake kit. Made my own "bottom dies" I rigged up along with having made my own gooseneck dies -
The problem is that the tool set the kit comes with, will not suffice for providing clean bends with a tight radius on smaller parts. Especially if those parts are made from thinner material.
If you look above in my current pic, you'll see a 20 ton Bend Press I got from Trick Tools. That thing got me hooked as it uses a 30 degree punch and uses a 4-way bottom die to use for different thickness materials. Only problem is that the punch is a single, non-replaceable piece and I can't use a different bottom die paired with the fact that it's only 10" wide.
Here it is in action -
Has anyone used the Cyclops Designs press brake attachment found on Ebay?
I'm especially interested in it because it uses EURO tooling and comes with a 24" 4-way bottom die (if purchased with tooling).
Unless there's an alternative I should be looking at?
I'm on a fixed income and short on space so just trying to spend my money wisely.
My small shop -
Press Brake attachment for hydraulic presses, euro/promecam tooled 610mm width | eBay
All material must be central to the press ram. Option 2- Single piece tooling. Option 1- No tooling.
www.ebay.com
