Hi,
First time tried to use AC manifold gauge, to check the low and high pressure in my car (R134A).
Used Mastercool 89661.
With the valves on the manifold completely closed, I connected the low and high pressure hoses to the car. Car engine was off. Yellow hose not connected to the manifold at all.
Slowly opening the manual hose valves, first one low and then on the high side, the gauges moved from zero.
Started the car, set AC on max cool. Kept the RPMs around 2000.
The low pressure did not change at all. The high pressure increased a little bit.
Shut off the engine.
Closed the hose valves and disconnected the hoses from the car.
Disconnected the low pressure hose from the manifold. The low pressure arrow stayed where it was, without moving at all.
Opened the low pressure valve on the manifold - the low pressure dropped to zero.
Same situation on the high pressure gauge - with the hose disconnected, the arrow dropped to zero only after opening the high pressure manifold valve.
I expected that, with the manifold valves closed, the gauges should show the pressure in the hoses. What I saw is that while they did show pressure, they showed only maximum pressure.
Is this normal? Defective unit?
