Help me pick from three floor finishes
Hank11
Tennessee
I want an easy to clean low maintenance floor that is non slip and not shiny.
I have three to choose from, from lowest price to highest:
1. grind to 100 grit, apply epoxy primer, apply polyaspartic top coat
2. grind to 100 grit, apply Coval primer then Coval Concrete
3. grind to 400, densify, buff/polish in sealer.
What makes the most sense?
KYCountryboy
Depends a bit on the "use" of the floor. The first 2 options will be more stain resistant but can be scratched more easily than the third option. Coval will stink strongly during application, but dissipates. Polyaspartic will also have an odor that will dissipate.
Shea
California
Take a look at TS210 by Concrete Sealers USA. It's a thin acrylic-modified aliphatic polyurethane with a clear matte finish and high slip resistance. It does not require etching in most cases, it's easy to apply and is low in VOCs. It's a durable coating that is great for those who want something simple-looking and not shiny. You can see our review of it below.
H
Hank11
Tennessee
The shop is combination wood and metal. No welding, rather machining. Some painting. The wood work involves glue, epoxy, and finishes. There will be solvents, but I’m not too messy with any of it. Sounds like the TS210 is ideal for what I do and will save me a lot of money over the three selections I posted in the first post.
So, a light buffing/brushing at 200 grit and apply? I’m willing to do that for uniformity.
H
Hank11
Tennessee
From the TDS from the maker TS210 by Concrete Sealers USA:
"For best results, surface should have an equivalent of 150-220 grit resin bond diamonds and be able to fully absorb a few small drops of water within 3-5 minutes."
Would the resin bond diamond pad be used with a standard floor machine?
Carchie
I know this thread is a bit older and you probably already finished your floor, but sharing this for anyone else searching for the same thing.
We had the exact same priorities: easy to clean, matte, and absolutely non-slip. I was also worried that standard polishing or sealers would get dangerously slick when wet.
After dealing with the same dilemma, I bought a solution from Stellmann Non-Slip Coatings. It didn't change the look of the floor or make it rough, but it actually made it safe underfoot. Totally worth looking into if you want peace of mind without the glossy finish.
GuyintheSouth
Wow looking at TS210 allgaragefloors site it says the matte TS210 has a good slip resistance rating of .65. They report "Our unscientific wet-slip-resistance testing confirmed that this is the least slippery coating we have ever encountered."
