What did *I* do in *MY* garage today?
I'll tell you what *I* did....
I had an attack of the ******** dumbasses is what I did.
Here's how it started:
Reading on line about the difficulties some people have with dropping the spare under the rear of their OBS Fords owing to rust & seized bolts etc. So I decided to drop the spare, clean up the area, clean up the wheel & bracket etc, even put dressing on the tire & sprayed some galvanize paint on a 1/2in rust spot on the bottom of the tank.
That was yesterday (when I sliced my thumb open)
Today I took the opportunity to clean up the birds nest of wiring & scotch locks (which I HATE with a burning passion) between the rear of the gas tank & the bumper etc. Zip ties, Adel clamps & proper harness wrap from Germany as used by Mercedes etc. This is after (I'm not done yet):
Then I decided the put the rear tire & bracket back on & the fun started.
Bolted the spare to the bracket with the BIG plastic nut thingie. Put it on a shipping blanket dragged it under the back of the dually.
Now bear in mind I'm dealing with a 20yo non-union fracture of the right scaphoid, complete with failed bone graft & a loose screw... AND intermittent grip in the left hand owing to Kaiser making a complete *** of the shoulder surgery (also 20 years ago)
So it's a bit of a struggle to get it in place, raised up (by hand at first, & then with a floor jack under it) & get the two bolts in, one at each end of the bracket. It took over 30 minutes to get it all lined up & the bolts started.
That's when the dumbassery struck I noticed had the goddamn bracket backwards. The end that went to the right/rear was at the front/left... ARRRGGHHH!! So I had to drop it down again turn it around 180 deg & raise it up again.
Got it all sorted now. FFS
Luckily I did this with it balanced on the jack so it only took a few minutes
The correct way:
nites.
