Using unfaced insulation?
MushCreek
Upstate South Carolina
I'm trying to find a deal on insulation for my shop. I ran across a good deal on unfaced batts. If I use them, what should I use for a vapor barrier? Is plastic OK, or should I use something a little more breathable? What about Tyvek?
Metal-Marc
Foothills of the Adirondacks
Plastic (6 mil) is what you want as a vapor barrier and if it's breathable, then it's not a vapor barrier.
MushCreek
I don't think that the kraft paper on insulation is a true barrier, ie, vapor proof. Or maybe I'm wrong; that's why I'm asking. Just like Tyvek isn't truly vapor proof; it breathes very slightly. This is in a wood barn in hot, humid South Carolina. I will run AC in the summer, and heat in the winter, but not continuously. HVAC will be a minisplit, used as needed (when I'm working out there).
acer66
Western North Carolina
