Antenna mast question anyone ever work or put one up ???
JBAUTO
Trenton,Ontario Canada
Hey guys my house has a 60ft antenna mast and the controler here is not working. I wanna take the mast down but dunno how i would do that. I have some ideas but would like to hear how these things were installed in the first place.
Anyone shed some light??
Josh
CraigFL
Panama City, FL
What kind of mast?-- round tubing? Guy wires??
Some slide into themselves, section by section. Some are taken down by each 10 foot section- starting at the top, while some need to be lowered to the ground first.
4StarCstms
Kentucky
I've put em up before, but never sixty feet worth.. gotta be on a two story house or supported somehow.. Cant imagine a mast supporting that kinda load without some form of support..now a Tower thats another story.
When we put up towers, we'll erect the tower, then climb it to mount the antenna usually, unless its a crank over style tower (way nicer!)
T1320T
Indiana
We took a couple of 3 legged towers down last summer, they were about 40' tall. We climbed up about 30' & tied a heavy rope to it, then attached the other end of the rope to a truck. I cut the legs of the tower w/ a sawzall as the truck pulled slightly to keep tension on the tower... worked well.
Mattlt
MN
OP, Google the term "Gin Pole" to see how this works.
J
JBAUTO
Hey guys i measured it out. Its 46 feet tall here is a pic of it.
J
JBAUTO
I looked at the whole assembly. There is no hindge on it. Possibly the hidge assembly is barried under ground ?
I was thinking of getting a few guys tie 3 ropes on it. One to lower it and one on each side to guide it down. Once on the ground i wanted to make 2 poles a hindge assembly so that i could raise and lower it with only one rope.
Loosen the bolts and lift it up a few inches put to side then lower it down.
Thirsty
Sparta Wi
This ^ ,You need a gin pole and take it down in sections. then you sell them on Craigslist. Some people leave the bottom section buried in the dirt, it is probably buried with cement.
BigMike782
Mine is just like that and I need to take it down due to a limb hitting it in a storm.Mine is 3 C shaped channels in a triangular layout with no means to hinge it.I am HOPING I can tether it to some 4X4s buried in the ground and use my truck to lower it down.Once it's on the ground I can build a hinge to put it back up.
RPH
Michigan Thumb
Looks like the one i have, mine the tower bolted to the cement mount. Unbolt one of the legs and it will hinge on the other two. Watch out for overhead lines and I leave it to you to figure the best way to control the decent.
Graham08
Iron Station, NC
Are these actually worth something beyond scrap value? I have a similar tower that I'm planning on taking down...I don't want to test it as a lightning rod. I figured I would sell it for scrap, but if it's worth more on Craigslist...
MotoDave
Ventura, CA
I bet a local HAM would be happy with a free tower, they will probably even have some experience in taking them down and would do it for free.
Eric Commarato
Mississippi
Contact your local Ham Radio Club. Many of them have gin poles to disasemble a tower like yours. Like the quote above state a local ham would love to have that tower.
Eric, N5XQ
KEH
First, locate the local Ham radio club. I assume the rotater is not working. Go outside and have someone work the controller. Listen to see if you can hear if the rotator making any noise. If it is dead quiet it is possible the controller is bad. Try another controller that is known to be good. If you want to get rid of the tower some hams would probably take it down for the tower. You need to feed them for politeness sake. Go to some club meetings, you might want to try Ham radio. You already have a small tower which is about 1/4 the station, an antenna being half the station. The radio(s) make up the rest.
DON'T try sawing the thing down. That's done only if the bolts holding the 10 foot sections together are too rusted to take out safely. If sawing is necessary, someone experienced should supervise it. Even a small tower has a lot of energy potential.
KEH
