rd65
Cleaned up after the water heater installation.
In the garbage can? So the test went bad?It's going in the garbage can. The old one actually primed pretty quick considering it only had 2 lobes. It was just a real weak stream.
Would have loved to been a fly on the wall for that one..lolIt was my work life. Then I retired. Then several years in I made the mistake of accepting the nomination for NWA President. Aholes are coming out of the woodwork. Stupid high school games. Thought I'd got away from this. The whole pack were overdue for a reaming. I obliged them.
I think I read that somewhere, but it’s entirely possible I made it up..lol The memory is the first thing to go after a bunch of concussions.lolIs that what it is? I had only heard about soy, and there doesn't seem to be a consensus about whether that really attracts the mousies..
Probably garbage can full of water.In the garbage can? So the test went bad?
The test will be conducted in a garbage can full of water.In the garbage can? So the test went bad?
Good hot weather / rainy day project. I almost always have a need to pick up and organize, and feel good with the progress.I keep track of what I have and where it is with an app on my phone. When something isn't where it's supposed to be, I move it to "No Location". Every now and then, I go through the stuff that is "missing" and try to find it and put it where it belongs. I was able to track down about half (12 items) and get them put where they belong. Mostly cases where I was in a hurry and just threw things in a box so I could "deal with it later". It's too hot to work on any real projects, so I am mostly spending time getting organized for when it cools down.
Lee
Solved both of the mysteries... (thanks to my good glasses)Confused myself. Was looking at the wiring under the dash in the F350 & found *something* that may, or may not be, a switch. It was close to the switches for the lights on the brush guard & the underglow... so I know it isn't for those.
Didn't have my good glasses at the time so will have a better look tomorrow.
I may have also spotted a funnel of some sort by the jack under the hood. Need to investigate that too.
Maybe the amount of hardener recommended has more to do with final hardness, and less to do with hardening speed?Solved both of the mysteries... (thanks to my good glasses)
The *switch* is actually a bolt & bracket that attaches the dash to the vehicle & the *funnel* is actually a 1/2in drive extension doodad for lowering the spare wheel under the back of the truck...
Having sorted that, I used some fiberglass filler on the running boards. Ratio's on the can looked a bit suspect, used half the amount of hardener & it kicked off it about a minute.
Second batch I used about 1/8 of the hardener needed & it kicked off just as fast. WTF??
This wasn't some old **** that's been sat in the garage for a decade, I bought it yesterday.
If I need to use more, I'll just wave the tube of hardener near the mixing board....
This stuff was harder than a honeymoon **** in fairly short order, did some sanding on it this afternoon.Maybe the amount of hardener recommended has more to do with final hardness, and less to do with hardening speed?
<<<< Not a body man.
Try setting refrigerating the two parts before mixing. Then make sure you keep the mix spread out.This stuff was harder than a honeymoon **** in fairly short order, did some sanding on it this afternoon.
Buddy coming by later to help lift and flip it up; I have a badly damaged back
You are a fabricator... Build exactly what you need so it either breaks down or can be otherwise stored or kept out of the way.(that and I'm poor lol)
A buddy, who didn't have a bad back or money, made inside his shop; I beam tracks on the sides, and a cross beam on trolleys, and a chain fall to start - later it was a powered hoist - and this took virtually zero space -needed 4 "legs" to support it - and he moved anything heavy anywhere in his shop by himself.
As a one-man shop and particularly if you have a bad back, and most especially if you handle heavy loads routinely, you own it to yourself. The cost compared to medical bills is nothing.
For a lighter weight system, you can do this with Unistrut. They make the trolleys; Those can be doubled up for higher capacity, you just have to watch the span capacity, - which can be effectively doubled if you bolt two struts back to back vertically.
https://www.amazon.com/s?k=unistrut+trolley+system&adgrpid=1333708167599443&hvadid=83357001281742&hvbmt=be&hvdev=c&hvlocphy=86841&hvnetw=o&hvqmt=e&hvtargid=kwd-83357102203833:loc-190&hydadcr=20495_13328415&msclkid=6bc2bbe156b712eeebc1dd33708b08e3&tag=mh0b-20&ref=pd_sl_2uugaulckj_e&tag=atomicindus08-20
Anothet thought - a Jib crane: https://www.amazon.com/stores/page/A4929B2B-9030-406E-B8CE-34A26E9931D6/?tag=atomicindus08-20
Agreed. My wife has a really good immune system. She hasn't been sick in quite a while. I think she's also under some extra stress that helped cause it. Some of her students are even more 'extra' than usual this year.Horrible how teachers are the mosquitos of sick. Unfair. Wish sick kids would stay home. But no one to stay with them.
