dwasifar
Made a base for the "model makers brass stock rack" I picked up (with some brass stock) so its less likely to tip.
Received Nickle rod for the portable plating setup I'm working on
re-ordered Critic acid that I can't find...
reassembled the Panasonic Radio "Jig saw Puzzle" - Shipping damages to the case from Eprey
ordered more AAA Lithium batteries as I used the last of them but one last night.
Critic acid? Was it this?
fishwatcher
I fixed my friend’s daughter’s bike so she can take it to college.
List of things I did:
Washed the bike
Cleaned and lubed the drive train and other moving parts
Replaced the rear inner tube
Replaced cracked derailleur cable guide
Replaced a frayed shift cable
Adjusted brakes and shifting
Added handlebar plugs
Tidied up the seat cover
Removed unnecessary accessory holders (old brake cable hanger, light bracket and pump peg that are long gone)
Easy stuff compared to what many GJers do in their garage. It was nice to take a bike that wasn’t working and make it functional and safe again.
New grips and saddle would be nice, but she doesn’t want it to look too nice due to campus theft concerns.
GirchyGirchy
Central Indiana
Washed the bike
Nice bike and good work! That's a perfect campus bike.
I worked on several friends' bikes in college and later, it's very satisfying to take a dirty, usually somewhat neglected two-wheeler and clean it up to nearly new condition. Parts can usually be had for cheap and are very interchangeable (assuming it's pre '10s), and most headsets and axles simply need a clean and lube.
If you like it why are you getting rid of it?
Because I "inherited" this, the '95 F-150 my dad ordered new when I was a kid. I've always loved this truck and have wanted it for years. There are certainly cons to going this route (big, slow, thirsty, 4X4 = more **** to break), but the pros (better condition, lower miles, more comfortable, more interior room, sentimentality, it was free, and just look at it) outweighed it for me.
This was taken just after it made it home, towing the Focus behind on a dolly. Luckily I'd driven it around a couple of times before the trip, leading to quick fixes of the hazard flasher and the multi-function switch...turn signals and wipers are nice to have. It's currently on jack stands in a neighbor's driveway after swapping its previous tires onto the Chevy in favor of new Firestone Destination LE3s. Hoping to put those on tonight.
Garage last night - topped off the Chevy's A/C and did some final exterior washing, then began cleaning up the mess in the garage from the Focus work. Frame extensions for the QuickJack showed up on Saturday (required for the Outback), need to unpack those and find a spot.
Notgrownup
Snow Hill NC
Nice older pickup. I am looking for a oOder truck orp,sun truck for retirement. My 22 Lariat is so full of tech I don’t want to deal with when it goes out of warranty. I will have ton of equity in it and will trade it even for something simpler in a single or super cab.
ZRX61
Solar Blight Valley, SoCal
There's a great '92-'96 Ford OBS group on FB :) What engine?
Bob Heine
Boca Raton, Florida
@GirchyGirchy, If the Silverado is paid for and you want to keep it, why not register and insure it as an Historic vehicle?
Indiana lets you do that when the vehicle is 25 years old and:
Collector Vehicle & Authentic Model Year License Plates
A historic vehicle may be registered as a collector vehicle for a reduced fee if the vehicle meets the following criteria:
  • Is at least 25 years old;
  • Is owned, operated, restored, maintained, or used as a collector’s item, a leisure pursuit, or an investment; and
  • Is not used primarily for transportation.
Then you can get collector car insurance from Hagerty or one of the other insurers for a pretty low premium. I have insurance on two old Corvettes for less than $600 a year. If your ford is laid up for any reason you'd still have a pickup to drive to a Home Depot event :dunno: .
GirchyGirchy
Central Indiana
351 with the E4OD.
I have no interest in owning >3 vehicles at the moment. The longer I keep it, the more work it will require, and the less money I'd eventually get out of it. I have three people lined up to buy it and am happy to pass it along.
Plus, I can use that money to put towards expanding the garage into the backyard. I'd love to have a spot to store the F-150.
driftpin
I have the exact same one, it's still in the original black plastic case but the hinge is getting weak.
I've replaced a few taps and dies over the years but the majority of it is original.
Craftsman Khromedge was pretty good back then.
I have the smaller version of that set (does not have the machine screw sizes) in the original case as well as the metric set, also in the original case. Probably close to 50 years old now. They've never let me down.
Here's my set in the flesh (steel) and the box it arrived in, part of which was too-cruddy, I cut-off the deteriorated cardboard. You can still read the shipping label, 'Sears Roebuck.'
I dose the pieces with PB Blaster about once a year, or if they look 'dried-out' and in-need of something anti-rust.
ZRX61
Was outside the garage & dropped a tray of 1/2in screws.... there were 32 in it. I only found 31. The F350 is out there right now & I dropped the damn things right next to it. They are for securing the rubber doodads to the running board steps. Even got a magnet on a stick & searched under the tires etc...
No ******** sign of #32... I just KNOW if I move the truck it will end up in a tire. FFS.
AND I counted them to be sure FIVE times... & they're black...
For sure
My question is what physical law attracts nails and screws to tires and then flips them so that the point penetrates the tire?
The common scenarios is it's always the rear tire, and what happens is the front flips the deadly object up, and the rear receives it... I once "collected" a screwdriver off the road and into my rear tire on my 64 Ranchero, and a week back a 2" metric bolt in the Toy family car.
Yes, I noticed the screwdriver right away! :rant:
I'll take What is Murphy's Law for $1K Alex.
:ROFLMAO:
Mike65
Horse Pasture, Va.
I spent a couple hours working on the Mustang. I replaced the r/s hood hinge & somewhat adjusted the hood, installed a fuel line gromet in the l/s front inner fender panel where the fuel line comes into the engine compartment, adjusted the hood latch, installed the fuel filler neck & hose to the fuel tank.
micromind
Fernley, Nevada, about 30 miles east of Reno.
Conducted two more (fruitless) searches for that goddamn screw.
Might try outer space...........
Whoever says that physics is always true has never had a small object fall 2' and be found 20' from where it fell. And sometimes it's at a higher elevation than it fell from.........
ZRX61
For the missing screw:
First place to look is directly under the center of the vehicle, where it's farthest from your reach. Second is under the farthest tire, then work your way around to where you dropped the box.
I got under the truck (with a flashlight), actually ran my hands around the tires to see if it bounced up & got stuck in the threads. It's a #6 1/2in pan head screw.
mreisner
North of Detroit
Replace a couple of windows in the conditioned part of a 40x80 pole barn. My dad and I put them in there over 30 years ago and they were windows that he put in The Farmhouse originally around 1960. Needless to say they didn't owe me anything anymore and they were getting pretty rotten, double hung six over six single pane glass, well used. As a kid I used to enjoy carving patterns in a frost of them. Not so much in the shop however. I replaced them with some Anderson thermal pane takeouts that I got in a garage sale for five bucks each. Not thrilled that it is a wood sash but a little bit of paint will keep them going for quite a while.
