KlinkSanford
- Joined
- Sep 9, 2024
- Messages
- 3
Bought a used Campbell-Hausfeld 60 gallon vertical compressor for $200 (not a one ID on it, it looks like an older VT6195) and in very good condition, the former owner upgraded and just wanted it out of his crowded garage shop. I opened the bottom drain and some water came out, maybe 1 qt, and then I took off the tank air outlet bushing, which is mid tank mounted, so I could look inside. I found it was wet but in good condition. The bottom drain outlet bushing would not come off easily so all I did was remove the drain valve. I have not had time to go further, I plan to clean the inside with my home-made brew of citric acid and baking soda. Anyhow, the tank has been sitting on the same spot for 1 week and water does not stop coming out of it, the compressor is sweating water non-stop. It is in a well shaded barn in Central Florida summer high humidity, but this sweating is a surprise to me. It appears that it may be better to close up the tank than to leave it open to dry up?
