You measure TVs diagonally - not trailersDiscovered what I thought was a 16' trailer is only a 14'. Not sure why I've always thought it was a 16...
Coincidentally, I did the rear brakes on my Chevy today too. Silverado.Rear brakes on a 2016.5 Chevy Cruze.
Raybestos EHT pads and they were friction rated as GH. Every other set I've used was GG so maybe the material changed?
What did you do for prep first ? Just wash it off, let it dry and apply or was there more to it ? I’ve been thinking about doing this to a few trailers for a while now.
Not today but yesterday at work got my **** kicked by this Camry. The guy helping me did too. We still haven’t figured it out. We spent an hour on it Thursday and 8-5 on it Friday. It was towed in with a crank no start. We suspected it to be a fuel pump but the pump is working fine. Wiring is fine. Relay is working fine. We have done so much electrical diagnostic testing on it that we are stumped. Third tech came over to help us and is stumped too. We jumped things and tested things and are just stumped. Hopefully we can figure it out next week. It was originally assigned to me but once I figured out it wasn’t going to be the fuel pump I went to my boss and said I need some help with this because I don’t know even where to start with electrical problems. So for the flat rate guy helping me I sold 2.5 hours of diagnosis to start then we sold 4 more. He already gets money for the hours I turn anyway so he will make bank off of this. I’m helping too because I want to learn. So that’s why I asked for help and got this tech assigned to it since he was my trainer I get to work with him still when I need it. And he takes time to show me things and let me do things. It has air and spark but fuel is not getting all the way thru to where it needs to go. Everything we tried doesn’t work. This is what I call an electrical gremlin. Unless we are all over thinking it and it’s something simple. But hey I’m learning and that’s what I value so no matter what we find the issue to be I’ll be very happy with the things I’ve learned so far.![]()
Looks good. My brother just uses motor oil for his new trailer. I guess oil and water don't mix. The pic is when I borrowed it for reference.
The person helping me is set on it being something in the wiring I think. But we need to check a few of those things. We know it’s getting no pressure because we put a gauge on it. But however fuel comes out of the lines when you disconnect them just no pressure at all when cranking.Is the ECU calling for the fuel pump to turn on? Does it pump when commanded?
Is there pressure at the injectors?
Are the injectors firing when commanded?
Has spark and compression. Don’t know regarding timing.Do you have spark? Has the timing belt skipped or broken?
We didn’t try that. It keeps acting like it wants to run but doesn’t.Does it run on an external fuel source(carb cleaner, flammable brake fluid. starting fluid)?
Not in my garage but a follow up on this post from last week. Since a stock CTS V dynos about 475 rwhp on that particular dyno, looks like I picked up about 125 rwhpReplaced plugs, wires, fuel injectors, supercharger intercooler & pulley, and added flex fuel sensor for my CTS V. It still had the original pulley so the whole blower needed to be removed so a pulley adapter could be pressed on. Any future pulley swaps will be very simple. Hopefully dyno tuning next weekend to find out I’ve picked up ~ 100 hp
Kick the tires and plug the, a wait a sec. Nevermind.If it woulda been my girl, I'd plug the tire and smack her on the ***..lol
That’s really good work—- is it hard to learn?
It looks a LOT easier with that rig than the one I did by hand about 45 years ago.That’s really good work—- is it hard to learn?
It’s not to bad.. I just got the power wrapper taking a little time to get used to… but I ve been doing it for years off and on on a manual set up..It looks a LOT easier with that rig than the one I did by hand about 45 years ago.
Can't really tell by the picture but guessing a LX version?Cleaning up this bumper cover. Going to be thinning some of my spare parts.
You are correct it is a LX version.Can't really tell by the picture but guessing a LX version?
Of course, 85-86.
The GT version for '85-86 were hard to come by for a long time until someone started to repop them. I have a spare in the attic, just in case.You are correct it is a LX version.
