Yes welded, not removeable.Is that Tommy bar welded?
Since you're inviting comment, if it was me, I'd take the paint off the swivel nuts.What do you think?
Thanks I was actually thinking about buying stainless for it. I need another screw for the plate that retains handle as well as new cap screws for the jaws.Since you're inviting comment, if it was me, I'd take the paint off the swivel nuts.
Yeah - I don't understand the pricing on some of these old vises (or anvils for that matter)..... Yes - they're cool and they were made well in the good 'ol US of A, but I've beat on my 'cheaper' vises pretty heavily for a lot of years and they've held up surprising well......Thanks I was actually thinking about buying stainless for it. I need another screw for the plate that retains handle as well as new cap screws for the jaws.
I posted it up on ebay for (a ridiculous) $650 OBO. Hey, I love old school Wiltons but could use the cash and if somebody wants to spend that much I'll let it go. I sold a 5" for $750 a while back we'll see how it goes.
I think alot of the value is driven by the collectibility and nostalgia vs a tool to beat on.Yeah - I don't understand the pricing on some of these old vises (or anvils for that matter)..... Yes - they're cool and they were made well in the good 'ol US of A, but I've beat on my 'cheaper' vises pretty heavily for a lot of years and they've held up surprising well......
I know. I guess after cleaning out 2 houses my parents had and trying to figure out what to do with all the collections and nostalgia things, I have no desire to purchase things that aren't useful just because they're cool.I think alot of the value is driven by the collectibility and nostalgia vs a tool to beat on.
I haven't had one apart in a while. Is it possible to rotate the end 90 degrees and drill for the pins. the tail would need to be ground and recontoured.Wilton prides itself on quality, but this one slipped by. Bought a C0 (mid 70?) on a flyer for $160. Locked-up slide. Screw spins. Broken ear on base. Missing dust cap.
Poor thing sat in the bed of a repair truck in NH for a few decades. But most of that time, it was painted , but wasn’t used. When I got it apart, I found out why. The nut wasn’t properly drilled. One side was not drilled through
and the shallow hole didn’t hold enough of the tapered pin, and so the pin sheared off. I’m guessing someone tried taking it apart, and did this to the end cap. Edit: looking at it, the screws on the horseshoe washer were all stressed, and bent, too. I bet the slide froze, but not the screw, and they jammed the handle until the nut broke free. So maybe the half drill hole actually saved the nut.
Thinking this can have a washer welded to it, and then machined down. But first, I have to get the slide unstuck, to see if I can even use it. Contemplating tossing it into a 400° oven for a 1/2 hour, spray Dust-Off down the screw hole, then whacking with a wooden dowel as a punch.
This has not been my most successful purchase so far.
Peter
That might be an option. It is pretty beefy. I’ve also heard welding this steel can be problematic.I haven't had one apart in a while. Is it possible to rotate the end 90 degrees and drill for the pins. the tail would need to be ground and recontoured.
Definitely a mystery (and a neat one at that). The red paint leads me to believe either Reed or RIDGID (though the paint might be after market), but I can’t find it in any of their catalogues. I might be seeing things, but is there faded stamping along the handle here?I have na unusual one I picked up today - and not much to go on for an ID:
got it at a Collage Flea - a solid brass/bronze vise - only a couple parts are steel. Only $10 so I grabbed it:
1-3/4" wide jaws and a 2-1/4" open. Weight is just under 3 lbs as is.
The star washer on this side is steel, and the square head bolt and spring are:
The "Cable clamp" and screws on this side are also Steel.
Everything else is "Non Sparking" and I suspect some of the steel parts were added after it left the factory.
It mounts to a round post and that post has to have one end available to feed the vise onto the post. The clamping ring is about 13/16" and no; 1/2" pipe is too big..
Bare metal under the red. My guess is that it was painted by one of the owners, a long time agoI have a Parker 49x that looks very similar it doesn't have any paint but not sure if that's original or not. It looks like there is a light green under the red but maybe that's primer? Not sure about Wilton either but have seen other wiltons with similar color. I just painted a 4" wilton marked 1-47 and it had Chicago USA on it as well would have expected similar markings but they could have done things differently during WWII. Both look great.
Bought the vise Friday, I picked up the puller this morning at a flea market for $5.If you ever find yourself needing to do that with a vise, that certainly looks like the bearing puller to do it with!
It looks similar to the old style of Bonding cable clamps I had used in the 1970s on electrical substations or steel towers when establishing safety grounds for conductors or personal protection. The bonding conductor is very welding cable like in appearance and it would be clamped to the bronze lug. The conductor jacket clamps under the 2 screw clamp for strain relief. The jaws clamp onto the angle iron or braces o the V groove would clamp onto smaller conductor wires. Pushing down and rotating the spring tensioned threaded screw and nut may present a differently configured camp profile.I have an unusual one I picked up today - and not much to go on for an ID:
I have to ask did you pay up or was it a $10 estate sale deal?As a lover of American history generally and vise history specifically, I don’t mind admitting that when I saw this vise amid other photos of a local estate sale, I took off work early and spent the night on the front stoop of the home in order to be first in line the next morning. As you can see, the rest is history.
I’m in utter disbelief at the condition of this vise. With 2” jaws and 99% of the original japanning, it is an exquisite, museum-level piece of history. The gentleman who previously owned it was, among other things, a photographer for Life Magazine.
Thomas Hall, a resident of Florence, MA, patented his “Improvement in Vises” on June 24, 1873. Thomas clearly wasted no time or money in advertising his invention, because less than a year later on February 1st, 1874, the Daily Herald of Dallas, TX writes (regarding the 1873 World’s Fair in Vienna), “Thomas Hall of Massachusetts exhibited a new and superior vise which received no recognition, while one ten years old, and which had been exhibited at the Paris Exhibition received a “medal for progress’.”
As a side note, I’m not yet clear on which patentor’s vise it was that received the aforementioned “medal for progress”. While I wish I could be convinced that the mysterious other vise was Mason Prentiss’, his was patented only five years prior in 1868, not ten. Additionally, the Paris exhibition was held in 1876, a year prior to Mason’s patent
While one might be tempted to pity Thomas Hall for his lack of recognition at the Vienna World’s Fair, one would only have to skim their copy of the August 21st, 1875 publication of the Scientific American to see not only a completely different story but also further information on the progress of Hall’s business dealings. The publication states while describing Hall’s vise, “This implement gained the medal of progress and a diploma of honor at the Vienna Exposition, such awards being, we are informed, higher than those given to any other vise. It also took the highest premium at the Fair of the Franklin Institute in Philadelphia in 1874…For further particulars relative to sale of rights, etc., address Mr Thomas Hall, 411 Fulton Street, Brooklyn, NY or Mr Charles Parker, manufacturer, Meriden, Conn.
Talk about being on the same planet but two worlds apart. And before you ask - no. There was only one Vienna World’s Fair/Exposition, and it was in 1873. Given the specificity of the Dallas’ Daily Herald comparison of Hall’s vise with the mystery vise that received a medal for progress, my suspicion is that the writers of the Scientific American accidentally either confused the two vises or attributed the medal to Hall when, in fact, he might’ve only received the diploma of honor. Either way, the contrast couldn’t be more stark between the two stories.
Ultimately, we know from these (and later mentions) that the Charles Parker Co was manufacturing Hall’s vises as early as August, 1875, and only a few years later the company would begin producing Hall’s vises bearing the Parker name. Given the Scientific American’s referral to write to Charles Parker regarding the sale of rights, I also imply that Parker had already purchased the patent by 1875.
