cliffcharb
I'm getting ready to wire up my 240v circuits in the garage and trying to determine benefit of using conduit/8ga THHN, or 6ga NM. Material costs are similar and will be run within the studs, nothing exposed
50amp circuit for the compressor, 6-50r Short run of a couple feet
50amp circuit for welder/plasma cutter. 6-50r. Max amperage 45amps (Plasma) with a run of approx 40 feet
50amp for the RV. 14-50r. A Longer run of approximately 80 feet as its going up and over to the opposite corner.
Is 80' considered too long of a run for 50amp service using 8ga thhn, or should i just move up to the 6ga nm cable?
