Brake caliper bracket bore reconditioning tool?
SuzukiGS750EZ
Hey guys. Looking to really clean out the bore that the slide pins go in. Previous owner didn’t do a great job on the brakes. I tried brake cleaner and a wire brush but it’s not really touching all the grime and whatever else I can’t see in it. Plus, I think they mixed grease with silicone…
Any ideas?
It’s a 2001 Silverado if that gives you an idea of the bracket size.
driftpin
I like Weiler abrasive products. Their grinder wheels are head and shoulders better than Diablo that HDodo sells. I bought a HD and the bench grinder jumped around like uit had the palsy. The Weiler was smooth like there wasn't even a wheel on it.
2ndGearRubber
Pittsburgh
Brush research makes ball hones in lots of small sizes.
This is my preference, saves the customer over buying a reman (yuck) caliper just to get a bracket.
I fill them up with penetraing oil and run the ball hone, partially because the oil helps wash away and break up any goopy grease left over. Hose out with acetone/brake clean, inspect, repeat as required. Blow out or let dry before reassembly, as you don't want the acetone mixing with your fresh silicone grease.
whateg01
doo dah, kansas, usa
That is why you should balance grinding wheels.
djbmw
Ottawa, Ontario, Canada
It also depends how corroded the hole is, and how long you intend on keeping the caliper.
Here in the great white north if the dust boot covering the pin tears and lets in the salt brine during winter, the pin can be rusted in place, requiring the red wrench to extract. The pin bore is usually pitted to high hell which would require either drilling to the next size up or replacing the caliper.
However... if its a winter beater and it just needs to get by a few more months then pouring some muraic acid into the bore hole and letting it eat away at the corrosion for 8 minutes usually is the hacky way to get back on the road.
