Inherited THW Wire
Adrien
Taft, CA
Hey all,
My Grandfather was an electrician and I inherited a lot of wire after he passed. I’ve been slowly going through all of it and used quite a bit for my shop wiring projects, mostly Romex and THHN/THWN.
I’ve gotten in to the depths and found a few spools of this TWH wire. Not super familiar with this flavor. Is it something I should hang onto or let it go to scrap?
Thanks,
Adrien
cgrutt
I would think you could get good money for that. I'd try posting it up on FBM or CL before scraping it.
ETA not electrician if @sparky 1971 says to scrap it may be worth less than I think.
sparky 1971
Central Iowa
It might be worth more than scrap to the right person that won't know what it is. It's been a long time, but I remember trying to pull wire out of new boxes and it was a *******. Now that those boxes are good and weathered, it ain't gonna be any easier and probably a whole lot worse. And, with no "N" designation, as in THHN/THWN, there isn't a nylon jacket that helps cut the friction pulling. It's more like trying to drag a rubber hose through the conduit.
I'm a cheap ******* and have been given rolls of the old style TW romex and used it even though it's a violation. There's no way I would even attempt to use the stuff in the OP, even for myself.
sparky 1971
Central Iowa
My bad, thanks.
I was getting mixed up with -B
Ya wanna know something that is really stupid? The conductors for -B have to have 90° insulation even though it's considered 60. The cheapest way to do that is to use THHN, but since nobody uses THHN anymore, it's probably THHN/THWN which should make it ok to install in conduit in wet locations, but since there is no way to show what it's made of, it's 60° inside wire, unless it's UF and that still has 90° conductors inside of it.
A
Adrien
Taft, CA
Thanks for all of the responses! I could probably start a whole thread of "What's this for?" with everything I've been sorting through, haha.
Adrien
