J H Williams vintage hand tools
Steven 33
Lathe bits? Probably not a huge collector thing, but you never know.
Turns out people pay a decent amount for the pieces in the case. About 30$ I'd say on average based off recent ebay sales. I decided to let it go last minute because I only wanted it for the cool case and I couldn't justify over 150 for that. But like you said "you never know" because if you think about it being a collector is basically just selective insanity ha. Someone spent 15k on a 20 year old McDonald's dipping sause and another spent 16k on a damn marble. Examples are endless, but yea I'm glad I got outbid ha. Sorry for the slight tangent but it is an interesting thought.
Definately a cool set, but I try to limit my scope a bit as If I did not I would definately be collecting way too many tools.
leg17
Kentucky
Williams machinist/metal shop tools just might make an interesting little side item.
Peruse through an older catalog.
Tool holders, jacks, clamping tools, etc.,.
Uh oh. I hope I didn't just give myself a bug.
A new member from the UK @GXA6 posted a spanner in a post linked here. I am going to reply here.
@GXA6
Your engineers' wrench is early. 2nd generation. No newer than 1924 and perhaps as old as 1913. The oval 'Brooklyn' logo is the key.
The "33" is very likely a very early model number. Model numbers (which would later become industry standard numbers, used by other mfgr's) indicated milled opening sizes, across-the-flats (AF). If it's a "33", the milled opening sizes would be 7/8" x 31/32".
The stamped "C" could be a suffix, though. As the demand for engineers' wrenches in multiple sizes continued to expand, Williams' numbering scheme was quickly overwhelmed. They started using prefixes and suffixes because the whole numbers were already taken. However, instead of making new dies, they would use the same forging blank and die. The major number (in your case "33") would be part of the die, they would just mill different openings in the ends, and stamp the suffix.
If it's a 33-C it would have milled opening sizes of 15/16" x 1".
As I discussed upthread, at some point in the early 1920's, at the tail end of the oval logo era, these wrenches were 75B, 77B, 79, 81B, and 83B (Williams dropped the "6" prefix)
Here is a wrench I found a few weeks back at a citywide garage sale. Still sifting through the pile, slowing moving things into working locations. Not a whole lot of markings on this one, but fortunately Lugz let slip that the wrench number belonged in the Williams family. This one does not have any maker marks, so wondering if it was private labeled for someone.
81B Made in USA and 11 on one side.
3/4 Drop Forged, and 13/16 on the other side.
IF someone can use this to round out a collection, let me know.
LNKMK8
Overland Park, KS
What am I doing wrong guys? I got this S-52 ratchet in a box of tools at auction. It has gotten wet at some point and the internals were rusted. I pulled it apart, soaked it in Evap-o-Rust, and everything cleaned up nicely. After putting it back together, it kept binding up. I discovered that as I ran it to the right, the threaded ring would move and tighten down until it locked up. When running it to the left, it would loosen itself until it came apart. How do you keep that threaded ring from moving?
Beerhippie
Far NE Oregon
Loc-Tite?
Is there a chance of a spacer missing that would allow you to tighten it down, without binding the works? Similar to having the right depth shoulder on a vise pivot screw, which when fully tight still allows it too pivot?
LNKMK8
Overland Park, KS
That was my thought as well... I guess I could take apart another one I have and see if something is missing.
And, in retrospect, it’s possible that the guts are not inserted all the way, and thus sitting too high in the body, colliding with the back. Maybe check that first, when you compare to the other ratchet, see if the anvil protrudes equally far.
Beerhippie
Far NE Oregon
Here's an odd--to me--Williams DOE engineer's:
I can't make out what the cartouche says, but on this side, it's a 128...
and a 129 on this side!
The end stamped 7/16 is 11/16" AF, the one stamped 5/16 is 1/2".
I can't make out what the cartouche says...
Almost certainly the oval Brooklyn logo. It's an early wrench. Pre 1913.
The markings are U.S.S. nut and bolt (diameter) sizes. The milled openings for a U.S.S. 5/16 x 7/16 engineers wrench should be 19/32" x 25/32", which are very close to your measurements.
Not sure what's going on with the forged marks on the shank. The part number for an early Williams U.S.S. 5/16 x 7/16 DOE engineers wrench would be 28. (A 29 wrench would be U.S.S. 3/8 x 7/16 with milled openings 11/16" x 25/32".) The same die was probably also used for 29 wrenches (i.e., same OAL, same shank, same head sizes and shapes), and the milled openings were different. Later they started adding prefixes to these numbers. A 1028 was a 28 size Superrench engineers wrench, for example. A 2028 was a 28 size Obstruction wrench. Same milled opening sizes. Different configuration.
Seeing a 128 and a 129 on the flip side is a little odd. I'm a little foggy right now. I'll go through my wrenches tomorrow if @leg17 or someone else doesn't reply to this first. But off the top of my head I don't recall a single digit prefix like that.
Catfishdan
Central coast, California
I found a really early midget set at a garage sale. A hex drive Williams electrical set. I haven’t done much searching yet, but it looks like it is only missing the sliding t, as the 286 set didn’t come with wrenches. No dividers in the box either. Doesn’t look to have ever had them.IMG_0051.jpeg
1942 J.H. Williams
DetailSeeker
South-eastern Ontario
I may have missed something, but I think I have a wood-handled Stillson-pattern wrench from J. H. Williams. It has the "W in a diamond" mark, and an asterisk in the divot on the head (both sides). (It also has a later C.P.R. stamp; I'm in Ontario, so I'm guessing that's "Canada Pacific Rail".)
I can't find any examples of a Stillson-pattern wrench in the Williams catalogs, but I did find a couple of 1921 advertisements in Canadian Machinery which show one from Williams, with the note that they're "Formerly Canadian Division of The Whitman & Barnes Mfg. Co."
I was wondering if it was something specific to the Canadian branch of the company, maybe already-forged W&B stock that was just stamped with the new mark? (Or possibly something specific to WWII, since I saw here that the < W > logo was sometimes used for wrenches then. But the handle seemed a bit odd for that, both because the wood handles struck me as outdated by WWII and because the wood had split and I had to re-glue it.)
@DetailSeeker -
I do not have an answer to your question, but HERE is a 1921 "Commercial America" advertisement showing all 39 flavors of Williams' wrenches after their acquisition of Whitman & Barnes which bears a striking resemblance to your Canadian advertisement.
Interesting question. Not sure if I can find an answer, but I'm going to shoot it to somebody who might know. :dunno:
you might want to keep these two links handy:
this one
and this one
and welcome to the site! :thumbup:
Stan S. said:
Williams took over the Whitman & Barnes wrench line ca. 1920 / 1921 including the Whitman & Barnes Canadian operation. They kept the W&B product line in production for some time.
Stan S. said:
There are some "transition" pieces with Williams overstamp on W&B made tools, but there are also pieces with only Williams markings. I presume that given Canadian "domestic production" legal protections, the Canadian products would have the appropriate markings, and if market conditions warranted, they may have kept some product lines going separate from what they were doing in the U.S.
Regards, Stan S.
@DetailSeeker
Welcome to GJ, thanks for taking the time as a new member to have enough etiquette to find the correct thread, and for posting such a well-constructed query, with some of your own research and suppositions.
No pipe or auto wrenches, either. I don't think they were shunned, but I do think it's indicative of where they ranked in their esteem. One gets the feeling looking through dozens of catalogs that they cut their teeth and made their mark with end wrenches, and forgings (lathe dogs, chain hoists, etc), and later, drive tools, and just never really embraced the things that were not in their original history. To qualify, the catalogs available in the public domain (on IA/ITCL) jump from 1912 to 1937 if I recall, followed by several throughout WWII and into the 50's. They wouldn't have been in the 1912, and by 1937 maybe they were a little passe. I don't know, but I have noticed the same thing.
I see that 4.c sought an external source to GJ for an answer, but if you search this thread (and the forum), you'll find discussions about the acquisition of W&B by Williams and the transition period producing all kinds of weird things. In addition to what 4.c's external source said about post-transition Williams era tools with just the W&B marking and Williams over-stamps on W&B markings, there are also tools with both markings. I actually have a little DOE wrench with three markings: W&B, < W >, and Globe Slicers, the name of a famous NYC deli! :)
One more note. Williams only bought part of the company. So, during this transition period, there were W&B marks on Williams tools when other divisions of W&B were still in operation.
DetailSeeker
@four.cycle , @Private Lugnutz , thank you both! The answers and details are very much appreciated; I confess I didn't notice the jump in the catalog dates on IA/ITCL, and didn't think to go looking for non-Canadian advertisements after I found the Canadian one.
Will definitely look for more details on the W&B and Williams acquisition here; I don't expect to run across more of the tools particularly soon, but it'll be neat to learn.
misterbill
I picked up this "first generation" patent pending S-52 ratchet and finally got a few minutes to disassemble, clean and lube it. Here it is posed with a later "second generation" model for comparison. One other "first gen" feature (not shown) is that the handle is bored out for (presumably) some sort of bar extension to improve leverage.
Bill
DetailSeeker
I picked up a Williams 14" Stillson-style this week, and I can't get the hook jaw out because the second thread from the end (on the inside, annoyingly) has been damaged.
If I had a spare nut, I'd try screwing it on from the end to see if I could use it as a makeshift die, but I am skeptical of how well that would work. Is there anything I can try to repair this besides "clamp it firmly into place and try to tap the misaligned thread back into place with a flathead screwdriver that has personally offended me"?
leg17
Kentucky
(Psst. Inside tip. -- If you have to use a screwdriver for a punch, don't tell us. Blame it on your wife. That's how we roll here.)
