Installing vinyl siding with nail gun?
Notgrownup
Snow Hill NC
I saw a video about some guy installing vinyl siding with a nail gun and commented about not wanting that guy installing mine and I got flamed… I just think installing it by hammer n nail is better. I a nail gun this adjustable that it will leave a piece of vinyl enough slack to move?
The Cobbler
set the air pressure and depth of drive so it leaves the nail slightly proud … in theory it would work.
not repeatedly , and I've not seen a roofing nailer or siding nailer that will adjust high enough to leave the nails proud.
I would not use, nor permit a nailer for that use on my house , unless it was proven to work constantly , not have nails miss the nailing strip, etc etc.
Old Man Roger
Palm Coast Florida
I’ve not been in construction so long that vinyl siding was then considered a cheap crappy siding, but wouldn’t it be possible to have special nails for vinyl siding?
Maybe kind of like a duplex nail, but with a shoulder instead of a second head? The shoulder would fit through the slot in the vinyl siding, but be bigger than the shaft of the nail. The shoulder, along with lower air pressure, would stop the nail head from contacting the siding.
Ok maybe I should have applied for a patent before I let this idea out..lol
All that being said, I think I could consistently run a nail gun in such a way that the nail would not go all the way in, but like I mentioned, it’s been decades, so maybe I’m delusional.lol
N
Notgrownup
Snow Hill NC
Ok, well now I know. I still wouldn’t . I see so many houses with buckled walls. I believe the video I saw was in Canada. I know they make some siding that is backed like a foam or something like that but not down here.
PCustoms
VT
Have you tried an actual building supply?
Jim greengo
Behind my house
I'd be more worried about the nail gun then the nail myself.
mrvm
PA
One big benefit to using nail guns for vinyl siding installations would be fewer ceramic tile cracks
mrvm
PA
Sorry stepped away from the thread for a bit. When the contractors finished installing vinyl siding on one of my rentals a few years ago many of the ceramic tiles on the bathroom walls were cracked from the heavy hammering. The impacts from driving in the nails with hammers rocked the 2x4 walls. Pneumatic nail guns would have been a better choice.
N
Notgrownup
Snow Hill NC
Damn, I don’t know what to say about that.
mrvm
PA
24" OC 2x4 framing and ****** tile install?
No termites ;) ....16" OC 2x4 framing and builder grade ceramic wall / bath tiling on green wall board. The outer sheathing was not plywood but a fiber board. I recall hopelessly leaning/holding the inside walls as the men were wailing away with their hammers. Without a doubt the pneumatic nail gun would have delayed a bathroom restoration.
PopcornSutton
Northern Tip of VA
I caught all kinds of hell from my wife when I redid a bathroom in our house. Just using a sawzall cutting out an old style fiberglass shower/tub unit, and knocked every picture off the wall on the other side.
dcg9381
Austin, TX
I know nothing about installing vinyl. But installing zip, I know there are attachments for nail guns that prevent the over-driving of nails..
DGZRT
Wisconsin, Stevens Point
When I did a 2 story rental by myself I found a star drive 1.25” long big head screw so much easier!
I didn’t have scaffolding so hanging off a ladder and using roofing nails was almost impossible. These self tapping screws were the cats azz.
I could adjust them in seconds if too tight . I found them to be a lifesaver. Yes they were more expensive but worth it .
PCustoms
VT
How did the smooth shank grip the sheathing?
Homebody
Northern Illinois
Is it easy to see the elongated slots in the siding with the head of the gun in the way? I mean - they ARE putting them in the slots correct??
DGZRT
There was plenty of smooth shank to leave a gap for expansion. It was an old house with 1” oak boards underneath. Trying to hold a roofing nail and drive it into oak was next to impossible. These screws with a Milwaukee M12 driver was very easy . With a good star bit you could load it onto the bit and not have to hold it . The whole process was much faster than nails .
Just cost me a 100$ more .
bwringer
Indianapolis
When we sided my house (hammered by hand), I went inside and found all the dusty useless bricabrac that was on the shelves on the south wall was now on the floor. The wall was fine; it's just that all the pounding set up enough vibration to eject everything from the light shelves screwed to the wall.
We got very fortunate in that nothing broke.
I can say that if I had known there were adapters to allow the nails to sit proud so you can use nail guns, I would have gone straight out and bought a nail gun and adapter without question. I was just the unskilled monkey trying not to get in the way of the guy who actually knew what he was doing, but he told me we couldn't use nail guns because you couldn't consistently control the depth.
Even on walls in good shape, there's enough variation in the material that adjusting the nail gun still won't give you consistent results.
I got royally, truly, incredibly sick of pounding nails. I learned a lot, and one of the main things I learned is that I really hate installing siding.
PCustoms
VT
Forgot I posted on this thread, searching for siding nailers and it popped up in Google...
giddygoat
I bulit in 1993 and the vinyl was installed with shingle nails, into osb, alot of it worked loose over the years, now the only way I put on vinyl is with 1 in flat head screws, phillips or star bit, they tend to stay where you leave them and not work loose. Just a quick as a hammer and nail and adjustable.
ipgenie
Idaho
I don't know about vinyl, but the steel siding I installed on my house 25 years ago was done with a Senco staple gun with a siding spacer adapter on the tip. It was easy to place the staples in the right spot and depth.
Maybe staples don't meet code on vinyl or maybe things have changed since, but they are what the supplier said to use, they were way fast and I've never had siding issues other than some unrelated peeling paint on the south wall.
