Snap On FK100 Thoughts
shoggoth80
Seattle
So, I put the newest ratchet in my drawer to use today. Snap On FK100. 3/8 stubby ratchet. Higher tooth count, thinner head, and shorter than my Duralast stubby. Jobs used on: thermostat and water pump.
I rather like it. There's a couple draw backs, but nothing major. First, I can sneak it into a lot of spaces. That's the primary reason I sprang for it. It performed really well for running down my water pump bolts. It also did well running down my thermostat housing bolts. Plop a wobble extension on there, and it's pretty versatile for fitting into my palm.
I think the steel selector lever is a smart change. It takes a solid flick of the thumb... But I don't mind that. I would rather have to make a deliberate direction change, than accidentally knocking the selector the other way.
It's a smooth mechanism. My FNHF100 is also 100 tooth, but it's also worn in at this point... So the roto is a little smoother. I think the stubby will wear in pretty similarly.
The back drag. That's a point I've read about. It's heavier than my roto 3/8 and 1/4, but nowhere near as heavy as my 71-10 1/2 drive. Nothing putting my thumb on the head, or putting a finger on the extension doesn't solve. Might be a big deal to others... But I've used quite a bit of old, coarse tooth stuff. Especially when younger. No big deal to me. Again, I imagine it'll lighten up some with use.
It also has the freewheel symptom if you push on the selector. This I'm meh about. It's not something I imagine being an issue, as there's not many spots I get myself into where I'm backing up into something that hard, or exerting that much force on that exact spot. It does take a fair bit of pressure to cause it.
Overall, I like it. Not the most objective review. Lol. Ultimately time will tell. First impressions are positive, and it adds a layer of extra capacity/capability to the box.
mreisner
North of Detroit
I have the Dual 80 version of that and I'm very happy with it. Been eyeing out a hundred tooth version, but concerned about the Back Drag on such a short ratchet. I've heard the newer versions of them are much better than the older ones.
The Critic
CA
Agreed. I have never used a ratchet in this manner.
wafrederick
Holton,Mi
They are stripping teeth out too, Found out a friend of my dad's has the flex head and he has had it warrantied once for this so far
jtrux
San Antonio
I haven't used the 100 tooth but have had a lot of success abusing the 80 tooth cousin. I actually ordered an 80 tooth locking flex head one today. The long version. I imagine it will be my go to from now on.
shoggoth80
Seattle
Part of me wonders if the folks stripping out gears in stubby ratchets aren't trying to use them beyond the intended purpose? On the other hand, it is a full size gear so???
So far so good on my end.
