Old Matco roll cab
cgrutt
Bringing home and old Matco 26" roll cab (probably 1980s) that I had at a friend's house. There is a center drawer at top that is double deep. When I try to close it it springs back open. Probably has something to do with the lock but I'm not sure. Any ideas appreciated.
I have the matching top at home. May clean them up and repaint. Not sure yet I love the style of this box lol. Call me old school.
crewchief888
NW indiana
if memory serves me correct, those spring loaded drawers were meant to be a "lock box" for valuables, keys, wallet, handgun, 1/5 pf bourbon ect
C
cgrutt
I don't think it's a spring loaded box and don't recall it ever acting this way. The lock locks the entire box not just center drawer. I'm not sure if it's the actual lock (tumbler) causing the problem or something in back of box that looks other drawers. I still have box in my truck and haven't looked at it yet.
impactims
Do you know why the center drawer pops out when you try to close it? Something with locking mechanism?
Yes, I do know.
You are supposed to push it in, put the key in, turn the key to the "lock" position then release the drawer. It will stay in and lock all the drawers in the process. That spring back that you notice is to allow all the other drawers to be engaged to the locking mechanism while holding the drawer in by hand, thus you have to push it in while turning the key.
I have a snap on box that is like this and I have had it apart.
C
cgrutt
Yes, I do know.
Thanks. I'll have a look but don't recall having to lock drawer to keep it shut. I'm not even sure if i have a key for it. Thanks for info though.
What I recall from older days, a 1/4 turn of the key would open the chest and not the center drawer, 1/2 turn of the key opened all the drawers. Or vice versa. Been too long since I’ve seen that in a tool chest.
C
cgrutt
Thanks! That may be the answer. I'm not sure if i even have a key for this box or how it got moved. Something in mechanism may have fallen off. As stated i don't recall it ever doing this believe all the drawers just opened and closed normally. I may not have even been aware the center drawer could be locked individually i can see why they would do that.
C
cgrutt
The top for this box has a key tumbler that just locks the top lid closed. There is a small lever inside back section of top that you need to manually slide to lock the drawers. So having the center drawer either lock individually or along with the rest of the drawers actually makes alot of sense to me now. Hopefully the key that I have for top matches the bottom. I did replace the tumbler on top section because I didn't have a key when I bought the box. Hopefully I replaced the bottom section with the same key but I don't remember. Appreciate the help!
C
cgrutt
So it does have a couple of bars that lock the other drawers about 3/4 the way back. The center drawer stays partially opened or drawers are locked. I honestly don't recall having to do this what a dumb design!
