kaymccampbell
Upstate New York
Is that a pipe for heating ?
Yeah, it connects both halves of the ductwork
His house is manufactured housing. They bring it to the site in 12 foot wide chunks on wheels, and it's plopped onto whatever foundation is provided. The main heating ducts run lengthwise through each half in a joist space. There's a big chunk of post installation ductwork that connects both halves, as the furnace is only attached to one side.
Prospecter
Maine
Set up shop out there, to work on the house floor. Finally.
Got the first subfloor board screwed and glued. Got the under house crossover hooked up and spread some goop over it. And a register crudely cut in, for at least SOME airflow/ heat in this part of the house. IMG_4948.jpeg
Only the one in the corner is glued/screwed. It’s midnight, and I have work to wake up for around 4 am. But tomorrow after work, I can glue and screw the others. Start getting this house back to livable condition. I have some more work to do underneath, but I’m hopeful I can at least get the living room buttoned up and ready for winterIMG_4949.jpeg
Those are some L-O-N-G hours! Looks good.
Mike65
Horse Pasture, Va.
Today after I got home from work, I removed the coil from #-7-cylinder spark plug & found the spark plug was loose. I removed the spark plug & found the "U" shaped piece that goes over the electrode was missing. I replaced the spark plug with a new one & re-installed the coil, & took it for a short road test, seems fine. The real test will be tomorrow when I have to go on some inclines at light throttle.
spark plug I removed
What the end of the spark plug is supposed to look like
Magnum440d100
Indiana
Thank you for further explanation. My brain was shut off and not doing brainy things lol
hdv32
Paragould, Arkansas
Got the dreaded PO304 code on my Miata over the weekend. I really think it as it was fine after I cleared it. However, on one of my previous Miatas I had to replace the catalytic convertor when I couldn't get it home quick enough. So rather than risk a $400 cat I decided new plugs, coils and wires were in order ( 2001 with only 39,000 miles ) a little maintenance would be worth it. $140 is certainly cheaper than a new cat. While I was in there I put in a new air filter and fuel filter.
Should be good to go now.
Wrench97
Southeastern Pa
If a new plug fixes the misfire buy a lottery ticket your lucky that strap didn't get stuck in a exhaust valve and have the piston hit it.
How many miles on that plug? And where did you get them you may want to have a look at the rest of them.
kaymccampbell
Upstate New York
Cleaned, flung, put away. Fixed a drying rack that Judy uses at craft shows. Loaded new software on the shoptop. Worked on a QR Code vcard tuit to go on Judy's craft show table. Worked on some other burner projects. Sanded a half a cup of CA that ate through the bottle and secretly catalyzed on the work bench. Totally ruined a pair of 3M P100 60926 filters.
oldman_pottering
Tinonee, NSW Australia
thanks, that's interesting. I have never had to deal with anything like that
jskicet
Western NC Mtns
Actually working on the wife's garage. It's been a messy disaster since her father passed and everything landed in her space. I'm surprising her by putting down some Swisstrax and I've ordered some NewAge pro cabinets. The floor went down in 3 hours by myself. Doing the trim takes twice as long. This is a pic before and after. The trim on the after wasn't installed yet. It's her turn being I've been spending all my time on my shop. IMG_7477.jpegIMG_7479.jpeg
Magnum440d100
Indiana
Got off work at noon. Made a lumber yard run for some supplies. Then home for more work on the house.
This is only up to the door to the mud room. Still have more to go, but it’s 11pm almost and work alarm comes QUICK. If I I weren’t having to replace or add 1”x4” for the seams, and other repairs, I’d be getting done quicker. But here we are. I’ll have a living room again. Still have to move the couch over, and the coffee table. I’ll turn the stove around as well. I’ll hold off on flooring until the other half of the house is done as well. It’s interesting walking on the stiff flooring and then transition onto the still soft stuff in the other half of the house. Eh. One project at a time.
58Yeoman
Central IL
Been working on the '67 Corvair back seat area for a few days. Previous owner had plywood shelf with huge speakers which were all crispy and shredded. I had ripped everything out, installed new plywood shelf, grey covering and small speakers, then reinstalled the rear seat. My body aches from climbing in and out of a small car. Oct16_24 (6).JPGOct16_24 (2).JPGOct16_24 (7).JPG
Old Man Roger
Palm Coast Florida
Not to be a judgy mc judge face, but would it not have been a good idea to stagger those?
Magnum440d100
Indiana
With where the HVAC ducting is, that’s 8’ from the other way. It would have been more material/framing/labor to stagger. As it sits now, the seam (non tongue and groove edges) are above 2x4’s. Had I staggered, they would only be above 1x4’s. I know the Advantech is rated for 24” OC, but I still wanted the seams above solid material.
FLHCHAZ
I'm still learing to weld, but managed to weld in the last patch panel on my Silverado. One of the cross members under the bed was rusted. I cleaned and welded in a new piece of plate. It aint pretty, but it is strong (and no one will ever see it when the bed is on).
bugnut
Central Ohio
Wrestled a used beetle door for the window winder, after clearing out the varmint home, to use on one of the projects, window is staying up with wood shims jammed in, gonna fix it so it works properly.
Prospecter
Maine
Renovating means figuring out solutions for what is there. Well done. Carry on.
Magnum440d100
Indiana
Just doing within my budget and time constraints lol.
If I would have staggered, I would have had to cut down full 4x8 Advantech sheets. As it is now, the right side is full 8’ and the left is 43”(ish).
I would have had to buy about 10 more sheets. And them bastards are $60+ each!
aShop
The Ozarks 6b
Time to catch up from the last couple months.
My wife had been complaining about the ride in the 200 series. I took it to Lexus for a bid. They said $15k to fix. Four hundred and twenty eight dollars later (accumulator globes) and and some ahc fluid and a mess and I had it fixed. Rides like a champ again. Wife and mother in law approved. This is powerful ammunition for a shop and a lift.
I started and stopped the truck a lot in order to keep the pump primed and about 2 days later the pumps that recirculate the exhuast gases when the truck has not been started for 7 hours and the temp is under 40 got a flap stuck open. This is a $2500 fix or you can go with the Hewitt bypass kit for better future reliability.
Armed with I just saved us $17k I did some much needed upgrades on one wall.
I ran drinking water hose to the corner with the 5hp pressure washer. Then back the garage washing machine. This is huge quality of life improvement when filling the water tank on the camper.
All the junk fit nicely in the Missouri made cabinet.
I finally hit that stage in my life when I need a dedicated rivet drawer
and a few more shelves for detailing supplies.
HPRifleman
Member Emeritus
Wayne, IL
Earlier this week one of my LiftMaster 8500 garage doors started to move only about a foot and the wall controller displayed a 1-5 error. Today the door company replaced the opener (under warranty). Since LiftMaster doesn't make the 8500 any more, the new install is a model 98022.
The biggest difference between the older and newer models are that the 98022 does not use a roller that rides along the cable. Below you can see the 8500 on the left and the 98022 on the right.
niget2002
Josephine, TX
Built a display stand for the wife's craft fair.
Then crawled around under her grand Cherokee to try and figure out where the slight oil drip is coming from. It's not dripping much.
I almost think the oil plug is loose, but there's oil all over the backside of the pan. I almost wonder if the pan gasket is leaking.
I'll spray it with a water hose and gunk off this weekend and see if I can see something more definitive.
