john.k
Just bought a small tire inflator .......much more convenient to dragging compressor hoses around to blow up a mower tyre.
May not be appropriate on this thread, but I've bought several tools that work on Makita batteries that are not Makita.Just bought a small tire inflator .......much more convenient to dragging compressor hoses around to blow up a mower tyre.
Yep lots of Chinese generic tools on aliexpress and amazon also are compatible with makita batteries. I got an angle grinder. Didn't have a big need for a cordless one so I wanted to grab one at Lidl or Aldi on special. Found something similar on aliexpress that uses makita batteries and figured I might as well have a chinese clone on the same system than another stupid set of batteries and chargers. Turns out it works more than fine for home use and is a proper brushless motor inside - I took the whole thing apart after I got it. Everything was dry. After some extra grease on all bearings and the head it also runs much quieter than on the first run. Overall very happy for the 30€ I paid for it!May not be appropriate on this thread, but I've bought several tools that work on Makita batteries that are not Makita.
One of them is a Mellif branded inflator - It cost $35 compared to over $100 for the Makita brand. Works fine. I've inflated many tires with it.
I bought a cordless hot melt glue gun - works great.
I bought a couple of LED lights - both very bright
I bought a cordless HVLP sprayer - seems to work pretty well.
I used the paper punching tool it comes with and hooked the sander to my shop vac. I found a plastic sleeve to use as a reducer. I was worried it might be too much suction, but the holes are near the edge of the paper so the sander doesn't suction itself to the wood. It worked very well.Thoughts on the dust collection?
LXT tools have a 3 years warranty check your receipt!Speaking of failures, my Makita 18v cordless fan bit the dust last week. It can't be that complicated so I'm going to try to fix it, but still annoying and disappointing. It wasn't cheap when I bought it a couple years ago
Both are consumer-level tools with brushed motors. The newer "BL" brushless models have electronic protection to keep the smoke in. Definitely uppgrade to those. I would suggest the XPH14Z or XPH16Z and the XDT19Z.Hammer Drill XPH01 had starting smoking
Yesterday, the impact XDT11 was blowing smoke
Thanks for the suggestions!Both are consumer-level tools with brushed motors. The newer "BL" brushless models have electronic protection to keep the smoke in. Definitely uppgrade to those. I would suggest the XPH14Z or XPH16Z and the XDT19Z.
Mine just got delivered, but I'm not home yet. It's only got like 30 lb-ft, so I'm curious to see how it will perform.I've been wanting this one for a while now. I was in a store yesterday and they had it on a good discount so I finally bought it. DTS141Z oil impulse driver.
I've been wanting this one as my old one is very loud, especially inside or when using it close to my ears. I've so far only tried a couple test screws but this one is a lot quieter.
Here is it beside my old battle axe, my DTD146.
Definitely targeting to professionals, not homeowners or DIYers.Makita recently announced the pack-out box system.
Looks nice, but as a homeowner I would have to be convinced it's a more efficient way to store tools and hardware.
Clearly a response to Milwaukee's Packout, which I bought a couple years ago. Fixes a couple of the Packout flaws, but otherwise seems pretty similar.Definitely targeting to professionals, not homeowners or DIYers.
I have wondered how the smaller XRH06 (sub-compact) model works. I have corded versions of rotary hammer drills but a smaller cordless would be convenient for a lot of my needs. Most of the hammer drilling I do is in the 1/4-3/8 range. Rarely do I do bigger and I do have a bigger corded drill for that stuff.There are many different Makita cordless hammer drills available, ranging from home-user grade to pretty good. I'm not sure which model you've killed or whether all of them are available in the USA. That said, hammer drills are all woefully poor at drilling masonry compared to SDS drills. I've tended to buy hammer drills, rather than drill/drivers, because they have tended to have slightly better specs for non-hammer drilling. I have only used hammer action on a hammer drill for plaster, sheetrock, etc, in the last few years. For brick, stone and concrete, I'll reach for an SDS.
I'm in the UK and the model designations are different to the US ones, even when they are exactly the same model.
I've had a 36V (2 x 18V batteries) Makita SDS for several years. I think it's perhaps equivalent to the XRH08. It's a great tool for installing 20mm hold-down bolts into concrete, but too heavy and ungainly for most of the lighter tasks that I also need to undertake. In particular, it's a struggle to use when up a ladder. It also hits much too hard for drilling brick walls, with a tendency to knock the back out of the brick when half-way through.
To save frustration and shoulder pain, I recently bought a DHR171 (I think it's the XRH06 over there) and absolutely love it. It is only rated to 17mm, 11/16", but is absolutely superb and does everything I've needed to do outside an industrial setting. It does most things I need it to do in an industrial setting, if I'm honest. The 17mm rating is reasonably conservative: I have used it for 20mm holes 250mm deep in concrete when would have taken longer to go and get the bigger drill.
I assume the "D-handle" reference is to the XRH08 and XRH06 layout. If so, it brings the centre-of-gravity closer to the hand, making it much easier to use one-handed. Your wrist will thank you.
The XRH01 is somewhere between the two that I have in terms of size, weight and capacity.
Unless you *really* need the maximum capacity of the XRH01, I'd recommend you take a good look at the XRH06.
What I have always called the D-handle is something like the XRH04.
Well that’s just dumb.. you'd think they’d design them to all work together.. so frustrating.I have the same vacuum and its hose doesn’t fit neither my XGT miter saw nor plunge saw.
I think it's because it's the same size as the common dust extractors are. I picked that adapter up for my track saw (and circular saw) but the Bosch hose (that fits the festool stuff and my Bosch sander) fits fine.
It only has 1 immediate use, but I'll report back.Let us know how the BL jigsaw performs. I have the older brushed model and while it is very nice, but I'm wondering if there are improvements.
