I been seeing cheap 200 to 300 piece mechanics sets for years. If you were designing one and cost was no issue but it had to fit in the same size blow molded case as a standard set, what would you put in it? Has to be general purpose but if you want to make it metric only I’m good with that. This isn’t a math puzzle I’m not actually going to count the pieces but keep it in that 200 to 300 kit size range.
Whats it for? Same thing that one of these cheap ones is used for. Homeowner who is going to do some light car repair and not be an expert, don’t need to be the fastest but can do most of the basic stuff he needs to do.
Curious to see if people go deep and shallow sockets or just one set of semi deeps like some sets have. If you stop at 19 or add in 21 22 24. What drive sizes, how many ratchets, which extensions, do you skip any sizes like 9 mm, do you start at 8 mm or go lower, what handful of pliers you pick, which screwdrivers or one bit driver and a bunch of bits, what kind of hex and torx you pick, regular combo wrenches or ratcheting wrenches.
Cost is no matter here put the most expensive snap on wrenches as long as it fits the size. Or don’t even pick brands and just tell me the type and size tools your picking. Heres a picture of a Harbor freight 225 piece set for size im thinking.
