Vent pipe elbows
bluedog225
Texas
I’m getting a bid from a plumber to putin the waste lines for my workshop/cabin. I‘d like to run an idea by the plumber before he starts…well, I forgot to ask when he was on-site.
Can I put three 90 degree turns in a 2” dry vent pipe? This would allow me to run the vent where I’d like it to exit the roof.
I would think it’s ok since it’s just handling air. But thought you guys would know.
Thanks
CraigStu
Blacksburg, Va
Could you do what you want using 45deg vs 90deg? I don't really know much about this but I think I'd want to avoid any level sections of pvc so rain/debris could find it's way to the bottom.
housewolf
East Texas
Thanks
If you are asking if there is a limit on 90 deg turns a vent can make before exiting the building, no. It’s fairly common practice to tie them together & run to the rear of the house in residential.
HoosierBuddy
Southern Indiana
I believe you are limited in the total number of feet your vent piping can be (consult your manual) and you have to add in "equivalent length" for all fittings used along with your straight sections, and compare that to the maximum allowed.
Engineering Toolbox reports a 2" 90-elbow has an equivalent length of 5.2 feet. So 3 of them would add 15.6 equivalent feet to your vent. Add that to your straight sections and compare to the spec.
manwithtools
Lebanon, TN
I don't think he's talking about a vent for tankless water heater, if that's what you referring to. I think he's talking about a vent for the waste lines for his plumbing.
manwithtools
Lebanon, TN
Thanks all. Yes, just the vent for the waste.
Then I think within reason you aren't limited in length of the vent other than a Max 5' horizontal run from any trap. As someone else mentioned, two 45 deg fitting separated by a few inches to accomplish the 90 deg turn is a less restrictive way to do it. Not sure it matters though. Your plumber can confirm. All horizontal runs dry vent should slope upward at 1" per foot.
