Mount lights to steel ceiling with magnets
Hey everyone, I’m installing a steel ceiling in my shop and planning to use Barrina 8’ long led lights. The lights come with mounting clips that are screwed to the ceiling. One thing I was thinking though is that since the ceiling is steel it should be possible to mount the lights with magnets.
The benefits would be no screws going through the ceiling and it would be pretty easy to reconfigure the lights if necessary.
Has anyone ever tried that?
Firebrick43
West central Indiana
Magnets loose power over time, plus vibration from weather or geological events could have an effect and the steel is pretty thin limiting holding power as well.
Mounting things on a wall were the magnets power causes shear friction compared to a ceiling were the power has to support all the weight.
It would be in the Darwin Award territory to be killed/maimed by a falling light because one was too lazy to drill a few small hooks. Or do 1000’s in damage if the fall on a nice car.
bwringer
Indianapolis
Should work fine. LED lights are usually very light. Yeah, I'd be reluctant to poke holes in my steel ceiling.
BrandonV
Arizona
Those are extremely lightweight. I see no issues with it. A quality neodymium magnet won't loose any noticeable strength for multiple decades far exceeding the lifespan of the lights.
cybrdyke
USA
There are plenty of LED light bars that include magnet mounts with them. However, the instructions always say that the magnets are there to hold the fixture in place while you install a screw. Some folks never install the screw.
CD
Leaflessshadetree
Don't ask.
I used magnets on a couple to figure out orientation, spacing etc. I put tape on the ceiling first to avoid scratches. For permanent mounting I attached rings to some of the screws that hold the ceiling up.
Chuckster in NJ
Hunterdon County NJ
Magnets are NOT approved for permanently mounting fixtures to a metal ceiling…….. Neither are drywall screws, adhesive, zip ties.
Would magnets hold up the fixture? YES! Until you get some seismic activity or storm activity and they get shaken loose.
BTW! There are some super strong magnets on the market nowadays. www.kjmagnetics.com
BrandonV
Arizona
I joke about this all the time when I see equipment mounted from the T-grid in office buildings. Every T-grid company I call tells me their grid is not designed to hold anything but ceiling tiles, yet I haven't seen a company NOT hang things from the grid.
cybrdyke
USA
There are lots of light fixtures designed to attach directly to the T-grid. There are also fasteners that are made specifically for attaching things to the T-grid. But, yeah....the T-grid manufacturers dont really like it.
CD
Higgins
Shepheardsville, KY
Not on the ceiling. Look at the HF large round magnets and believe me they would hold a typical light to the ceiling
tarbellb
Oregon
Magnets will def work, just two strong countersunk disc at each end and your gtg
also consider using quality double stick tape like 3M VHB. If done correctly it wont fall, ever, probably bend the fixture trying to pull it down.
imma_stocker
Waller Texas
Neo magnets from HF are barely strong enough to hold picks to the side of my cart. I would not use them to hold anything overhead.
