Just don't use restrictive fittings/hose/preferably regulator and you will be fine.
It DOES make a difference if you use restrictive fittings because you are under gunned on storage so you want your impact working as efficiently as possibly. If you give it 90+psi(at the tool, with the tool running) it will remove bolts/lugs much faster then if you set the regulator to 90psi at the compressor, use a long *** hose, with a low flow fitting.
This matters because if you are under gunned on storage/pump then if the gun doesn't remove the fastener pretty efficiently you'll be waiting.(And waiting, and waiting, and if the fastener is actually tight you may just not have the HP to remove it because you're not feeding the gun enough)
Feed it properly with a 3/8" air hose, preferably no longer than 25ft, and v-style high flow fittings. If you can, run your hose with a shut off valve right off the tank(if tank pressure is 125psi or less) and don't regulate it back at all. If the compressor has a decent regulator on it you can run it right from there, but most of them are more well suited for air nailers etc.
If you're looking for a second hand gun stick with IR
