Rockwool insulation gap
Beachomatic
New here and hey everyone. My wall is below grade concrete. Its not exactly true so I left a gap up to 2 inches in some places to accommodate a straight wall. The issue is that there will be a 2 inch gap from the rockwool to the drywall. I cant seem to find a consistant answer whether this will cause future moisture issues. Thoughts?20241030_131627.jpg
manwithtools
Lebanon, TN
It should be fine. Any moisture issues would only come from outside the concrete wall or up from the floor below. Air is a pretty good insulator, between your foam boards and rockwool you should be in good shape.
rlitman
Long Island
You're doing it right. I would suggest filling any gaps around that pink foam with spray foam. The pink foam, is already a vapor barrier by itself, but it needs to be sealed in place around the edges.
Is that a pressure treated sill (I hope so)? Gotta use hot dipped galvanized nails going into that.
mike93lx
Richmond, VA
I think I'd install it tight to the drywall.
Also would use 2x6 insulation if there are a good amount of gaps like that
@Metal-Marc you cant really compress rockwool. It's already very dense
Fav Onefour
MN cold and hot
Dang good advice.
To the bold comments. Don't forget sealing the top and bottom edges.
Beachomatic
Ok. Yea the floor plates are definitely pt. I did seal on the top and floor behind the foam board with the fire foam. Thanks all
bluedog225
Texas
If you have at least 3/4” gap (either side) , reflective barrier will keep heat in. Have to have the gap. Reflectivity or emissivity magic.
Would be good to know generally where you are in your profile.
manwithtools
Lebanon, TN
This is on a below grade concrete wall, not much a reflective layer will do in this case.
