Opener install question
mike93lx
Richmond, VA
This is a 16' x7' sectional door with a perfectly functioning opener. I'm swapping to get battery backup. Spring is torsion, if it matters
The current tracks are installed sloping downward slightly towards the back of the garage, 0.5" over 7'. The opener is down 3.5" over 7'. You should be able to see a difference in the pic below with the laser line
There is no binding and the elevation difference is easily taken up but the lifting arm
Should I reinstall at the same position or should the GDO be at a similar pitch to the tracks? My gut is to go back the same as what it is since it's working, but that doesn't mean it's right.
Fav Onefour
MN cold and hot
The level sure provides a nice visual.
Tracks aren't too bad. Unhook the opener and lift the door to end of travel. Does it roll on it's own past open height? I bet the tracks aren't enough to cause that issue.
The opener rail is off a surprising amount. It must be close to the door at full stop height. If you're already replacing the opener, just install the new one higher. Unlevel track isn't a deal breaker but they do flex. If it's too close, you'll be gunking up the door.
mike93lx
Richmond, VA
The opener was swapped the week before we closed on the house 3 years ago. I wouldn't be surprised if the old opener's alignment was different and the installer just kept it simple. I rarely open the door, but it moves smoothly.
steves_001
Southern MN / Northern MN
The slope looks fine. Usually the instructions mention a 2x4 placed on the top of the open door to set the proper slope from the header connection, (1.5 in). If you were to run that same 1.5 in level back to the header you would hit springs/torsion bar in most cases. There is no call for having it level I've ever seen. Your current install looks just fine.
ps. that slipstream canoe looks nice!
mike93lx
Richmond, VA
Thanks
Thanks again. I just wish there was somewhere to paddle it in VA... I bought it (and the other one thats wrapped up in the background) when we lived in MA... Tons of rivers and ponds.
firebirdparts
Kingsport, TN
"Should" is a difficult word here. You are absolutely allowed to install it like it is, and then run it, and see if it works. That's fine.
mike93lx
Richmond, VA
It's installed. I cut 3" of the hangers (I love the M12 cutoff tool) and it operates just fine.
