Hohn
I couldn’t resist the chance to get a project and a major compressor upgrade at the same time.
Local seller had a Champion VR5-8 for $200 with “an electrical issue.” I figure it’s probably a motor issue of starting cap or something. If the tank and pump are good, it’s worth the $200 to me.
Turns out, it’s got a 3ph motor which I’m sure is useful in some cases, but as a home gamer, not as useful to me. I’ll be swapping the motor to single phase. Obvious not a “starting cap” issue.
It’s got an oil level monitoring setup too apparently. I might remove this if I can’t get it to stop seeping. Pictured is a “the guy you want to know” and his son/helper.
