BTL-A4
I'm learning to weld. What clamps would you all recommend for general use?
So far, I've made a handle for a vacuum sled that has mitered corners (three 1" square tubes in a U shape). I have plans to make a wood rack that has mitered corners.
MITER/CORNER CLAMP
So far, I've needed to hold square tubes (I will not use anything larger than 2" square) at 90º. There are a few types, what would be best for welding?
clamp type:
[IMG alt="Name: corner clamp 1.png
Size: 127.4 KB"]https://weldingweb.com/vbb/attachment.php?attachmentid=1801789&d=1731698794[/IMG]
positioning square type:
[IMG alt="Name: corner clamp 2.png
Size: 170.2 KB"]https://weldingweb.com/vbb/attachment.php?attachmentid=1801793&d=1731698829[/IMG]
F-CLAMPS
What sizes? I'm thinking 6" and smaller to hold tubing to the table while I weld it.
BAR CLAMPS
metal (NOT plastic) ones. I have quite a few of these for anything larger than 6".
VISE GRIPS: I'd like something I can use with one hand to clamp items to the table to hold. 3"-4" range?
[IMG alt="Name: clamp 3.png
Size: 93.8 KB"]https://weldingweb.com/vbb/attachment.php?attachmentid=1801797&d=1731699089[/IMG]
I have some BAR and PIPE clamps.
CLAMPING TABLE
I've got a dinky little portable, folding welding table and the garage floor for work surfaces. There are a few homemade metal tables on CL and FB. Are these something I should look into? What about this at Harbor Freight:
[IMG alt="Name: clamp 4 table.jpg
Size: 58.6 KB"]https://weldingweb.com/vbb/attachment.php?attachmentid=1801799&d=1731699752[/IMG]
I'd prefer to buy them as I need them, but would like to look around for sales and used ones.
Thanks!
MITER/CORNER CLAMP
clamp type:
F-CLAMPS
BAR CLAMPS
CLAMPING TABLE
Thanks!
