lol, I was going to suggest you google Fritz and Franz
www.instagram.com
Jar, by all accounts we had the northern lights over us here in London/ south east last night.
Obviously I missed them but I have been sent a photo literally five minutes before my daily GJ check in.
You’ve seen it, I see on another thread.
Steve![]()
Spectacular Northern Lights show in Gold Canyon AZ on Thursday.![]()
NOAA issues severe geomagnetic storm watch for only the second time in nearly 20 years
A strong solar flare is heading for Earth, and it could impact high-voltage transmission lines for power grids and satellites.www.oregonlive.com
I heard they are viewable in Big Bear. Nothing here.
Have you considered Sherwin Williams Emerald Urethane Trim Enamel? I have had excellent experience with the product. It applies easily, lays out flat, and has a relatively quick recoat window. Overall cure time is not as fast as some but it cures hard and has been incredibly durable.
After trying the new sw emerald urethane and my normal go to BM advance back to back. I think I'm a convert.
Only took a couple years to figure that out. Contractor pricing on emerald actually makes it somewhat cheaper than advance.
I've used that on cabinets and doors and it always turns out nice. My paint company owner buddy got me hooked on it, and lets me use his company account too which like you said makes it even better.![]()
I've used the SW emerald urethane extensively on all trim and doors in my house. not sure if you are spraying or brushing but I brush. I mix in Floetrol and it will level perfectly every time. my wife and anyone else that looks at my painting swear that i spray based on how well it levels.My only complaint is the sheet is one level below what I'm used to with advance. The semigloss emerald is closer to satin advance. The other being it does not level out as well as advice, but it doesn't run nearly as bad, so I'd say that's an overall neutral difference.
more broadly, i now mix in Floetrol (for latex) and Penetrol (for oil) for all paints now rolling and brushing and won't ever go back. spraying is a different animal so this may not apply to that.
I like the 611 format over all the other trim routers. Hopefully this is close enough with all the weight on top.
You have a coffee bar in the bedroom?I knocked out a few doors/end panels last night for our master bedroom coffee bar that we will never actually use..lol
I started to set the cope cut on the saw/shaper, but realized the spindle it tiled rearward slightly. The benefits of having 4 shapers is just using a different one.
Cutting and then coping some cute little rails (I run the sticking first, and cope with clockwise and counter clockwise heads. The sled makes even these tiny rails straight forward.
Ready to final size. The end panels are 1" thick, the doors and drawer are 1.150"
I would never make it out of there.![]()
At some point it might just be easier to move your bed into your kitchen.
I wish I had your skills, you're my spirit animal![]()
Really nice work.
You do make it look easy!
Sounds like that new slider will allow different methods -- hopefully better use of your limited time as well.
Seconded.Well congratulations! Life as you knew it will cease to exist.
