2024 Garage Sale Thread (13th Annual)
Status
Not open for further replies.
Smokeshow69
I'm likely keeping it , but what do you think it's worth realistically?
** I dont know much about delta prices...you really should ask this question on the delta thread but I think you could probably get over $300 for it? **
I hit that sale around noon today, and the Goodell Pratt boxed push drill that I hoped would still be there was gone, along with anything else I might be interested in. But, I did see a coyote in the park down the street. So, I got that at least.
**Yes but at least you didn't come away empty handed from your trip north**
Southern83
North Carolina
The grinder stands alone can bring $300. His stand is the earlier version so that will add to its value.
JMP
Just scored this 1/3 hp Craftsman bench grinder dated to 1964 and all these tools today. The grinder was $50 but all I had was 20's so the seller asked if I wanted a small filing cabinet with misc. tools inside for $10 so all in for $60 which was a deal I couldn't refuse. Even though I did open it I didn't realize how much was actually inside until I went to unload everything. I kind of feel bad offering $40 on the grinder when talking on Facebook but the seller had only one blurry photo, didn't know the hp, and I didn't know it came with the lamp! The grinding wheels are original and will need to be dressed but it runs like a top. Also someone in the past had even replaced the power cord with a grounded one.
mikeinri
You ****!
Mike
brockmub
Sioux Falls, SD
yup you ****, definitely more than $10 worth of tools.
NYBODYMAN
NY
WOW!!! I'm glad my son pushed me into buying this. I almost left it there. I will inquire on the Delta thread. Thanks fellas.
Fred Knox
Nor Cal
We were gone the last couple weekends, so I searched "new territory", so to speak. I hit two garage sales and found:
Illinois Iron & Bolt (II&B Co.) No. 5 Anvil (pre-Vulcan)
Chas. Parker No. 973 1/2 vise
vintage Dazor model 602 clamp-on shop lamp
Millers Falls No. 51 sill borer
Plomb No. 227 duck nose pliers
Colton No. 10 file cleaner
L.S. Starrett No. 1 7" replaceable jaws nipper cutter
tiny 4” nipper
Starrett No 283 standard gauge 0-36
clipped set of six English Superslim DOE wrenches
Starrett 565 drive pin punches in wood case holder
Snap-on 1/2" x 1/2" universal swivel
Irwin auger brace bit set in canvas roll
vintage non-ratcheting bit brace (great look but no markings; cocobolo head)
Snell and Atherton No. 6 convex heel spokeshave
Snap-on metric combination wrenches
copper metal sheet foil
auto body dolly and blacksmith hardy and anvil stump tools
double sided 400/1000 diamond sharpener paddle
H.D. Smith 4 ½" perfect handle screwdriver
Crescent Tool Co. 923-7 flush-pivot slip-joint pliers with side cutter and great knurling
Lufkin Rule Co. No. 2504 6" square/rule
early Stanley Rule & Level spokeshave (only 9 ½” with 1 ½” blade)IMG_5347.jpg
Cruzan80
Denver, CO
@BD55, I have always heard those called telescoping gages, not bore gages. When I think of a bore gage, it has a large dial on it for measuring directly. Just semantics, but...
I would also practice taking multiple measurements against known sized samples to see how well you can hold to a size. It is a bit of of a learned skill, and some are naturally better than others. At a minimum, it will show what tolerance you can hold using them.
If you already knew all of the above, apologies!
Do the Starretts have a friction/ratcheting section for tightness?
ctuai
Des Moines, IA
@JMP you ****!
Here’s my score - $80 for a NOS Starrett set of mics, just missing the middle standard, a Mitutoyo mic and caliper a set of bore gages, and a drafting set. Th timing was great since I just got my lathe all set up.
Nice find. Gauges and to have a lathe to use them on. That's definitely a u ****.
BD55
Northern Utah
Thanks! Yes - I was lazy in saying bore gages but you’re right, they’re telescoping bore gages. And yes, the back part of the barrels of the Starretts slip.
Cruzan80
Denver, CO
All good. Some people tend to get caught up in small details, so didn't want you to get "yelled at". Glad to hear the Starrett's slip. IME, you will find you like one kind of brand better than others for things like micrometers (and end up with at least half a dozen other 0-1's gathering dust)...
alinc100
Dearborn,MI
Two sales today.
ESTATE SALE #1
CRAFTSMAN BIG slotted screwdriver
CRAFTSMAN 6mm x 8mm,10mm x 11mm doe
CRAFTSMAN 1/2” dr ratchet
BOG MFG. MASTER socket set
ESTATE SALE #2
BESSEY 6” tradesman clamps
STANLEY #140 skew rabbet plane
STANLEY #130 double end block plane
CHROME ALLOY 1/2” dr & 3/8”dr ratchets
CHROME ALLOY 1/2” dr 1/2”,13/16”,7/8”,15/16”,1”,1-1/8” 12 pt sockets
TIGER 1/2” dr 7/16”,1-1/16” 12 pt sockets
SK 1/2” dr 11/16” socket
SK ⅜” dr 9/16” 6 pt swivel socket
NEW BRITAIN 1/2” dr 3/4” 8 pt socket
CRAFTSMAN 1/2” dr RHFT ratchet
CRAFTSMAN 1/2” dr 7/16”,9/16” 2@1”,1-¼” 12 pt shallow sockets =v=
CRAFTSMAN 1/2” dr 1/2” , 5/8”,3/4”,2@15/16” ,1” ,1-⅛” 12 pt deep =v=
CRAFTSMAN 13mm combo,1/4” X 5/16” doe
J.H.WILLIAMS SC-8 ADJUSTABLE CROWSFOOT
J.H.WILLIAMS 1/2” dr 2” EXTENSION
alinc100
Dearborn,MI
a big suckola for alinc on just those two Stanley block planes--both very collectible. The rest?--icing on the cake.
Tom B.
I was waiting for someone to notice those. I actually have a 140 that belonged to my Grandfather in my shop, of course it's been brazed and I made the replacement side plate when I was running a waterjet. This one will get a light cleaning and sent to the bay, I will have to acquire 1 side plate screw. I'm sure I have a knob in my parts bin.. There is another interesting piece in the bunch as well.
bmwrd0
Beaver Fever Oregon
On Friday, I was able to sneak out and hit three sales, all the while avoiding the Black Friday madness for the most part.
First was a tool (and jewelry and china, but whatevs) sale were I found the geometric C push driver in box (with bits and instructions!), an Armstrong 1" combo, and the Goodell Pratt 1 push drill. Second stop had nothing of interest, but the third stop was the surprise. I didn't have much hope for it, as no pictures. But it was on my way home, so I figured what the heck. And here I found the Snap-on Vacuum Grip needle nose, Klein Kurves (my favorite wire strippers) and, best of all, an Armstrong ignition set, only missing the pliers, which I am sure I have a pair of.
And today will be spent putting up the Xmas lights.
alinc100
Dearborn,MI
I've never seen an adjustable crow foot before. Who made that?
J.H. Williams , it is an SC-8. A search here at GJ shows they were in the catalog around 1952-1961. The 3/8" version is a BC-6.
alinc100
Dearborn,MI
Some nice pieces there Alinc. You hit a couple good sales.
Thanks, I hadn't been shopping in awhile, these two sales popped up and were close enough together that it made sense to drive to both. The planes were a surprise and I had to look twice to realize it was a 140, thankfully I knew what it was. The 130 was a bonus. I left behind a couple block planes due to missing parts/bolts replacing screws etc. The adjustable crowsfoot was a very unexpected surprise, The BOG set had caught my interest in the pics, but only as a vintage set, couldn't tell the maker,etc from the listing. I had a good morning and I am glad I went.
NYBODYMAN
NY
The estate sale where I purchase the Delta grinder last week had a last minute posting this morning so I ran over to check it out. I was hoping the old Cman drill press would still be there but it was gone. There was still an old Delta Rockwell planer and a TON of old Porter Cable USA made power tools in excellent condition still in their metal cases. I don't have a need or know enough about them to even think about buying them. Also a ton of woodworking hardware.
Oh well....I found a few goodies that I could have lived without but also couldn't leave behind because I know it all likely end up in the trash.
Ten bux got me all of this:
Possible old military wrench roll marked "BG-30", ball peen hammer (possibly Maynox?), Wiss tin snips, Stanley chisels, Sears tire patch tins, Red Diamond adjustable, Pella clock that works and was made in USA, and what appears to me to be a very old Master Lock unfortunately without the key. @jeffmoss26 maybe you have some insight.
Status
