Mortar question
Mike in Ohio
Canton,Ohio
I have to replace a basement window this weekend after an attempted break in, going with a pre made glass block window. We are expecting a high temp of 43 on Saturday, inside the basement will be low to mid 60s probably. Do I need a special mortar or an additive for that outside temp? I've installed these in new construction once but never as a replacement, any tricks I should know about?
Thanks
Mike
PCustoms
VT
Thanks
Mike
How quick can you work? Maybe one of the fast set bags is a good idea...
cgrutt
How low will temp get? Want to protect from freezing temp for first 24 hrs. I believe they also recommend heating mixing water and/or sand to min above 40 degrees if temps are expected to drop between freezing and 40 degrees Fahrenheit.
Article attached on mortar considerations for glass block.
Cold weather considerations:
zendriver
Indiana
I did not know premade glass block windows were a thing. Learned something new
The only way for ease of standard install.
I did mine (five) two years ago with the units with the little screened vent window in the middle. Way better than the **** steel frame windows and boxed in insulation. Cut out the cold great.
To ease grouting I used a grout bag, to basically squirt grout into the edges.
Nice work, OP. FWIW Grout should not touch wood, normally, if you used it on the top. I used spray foam.
Kaizen
New England
If i were you i'd be making steel frames with prison bars or something on the inside of that and other windows as long as they are not larger exit type windows. Thieves talk. Something that you can secure into the sides of the openings. If you want to keep ventilation attach on outside with security screws.
Dagny
Northern Wi.
I put that same thing in my basement window where we used to throw wood in. I set it in GE silicone then caulked all the way around it inside and out.
hobie18
Our glass block seems to have lost its r-factor. Ideas? Even putting outdoor window plastic is on the table
