Kitchen Utensils.Stainless Steel?![]()
... and my titanium spork is under 20 g!
An image search brings up Shrader valve stem caps in a shorter box. No clue what that thing would be used for.
There is no cutter correct? Cuz if so they are probably a short lineman's pliers, I have seen vaguely similar from Utica. But I think that these do not have a cutter and they look more like some crimping pliers I've seen, but for sure not the same.
When you pull on it, what is the calibration scale?
BINGO! (applies dope-slap to self)I think it holds a 3/16" hex shank for socket head cap screws. It's nice when they make them removable like that.
edit-- I've got a few shortened Allen wrenches that I've cut an end off of, to use in sockets like those. Or, more often, inside regular sockets. Sometimes, with a little tape wrapped around them to keep them from falling out.
Hay, coffee bags, etc. Osborne made a variety, maybe they will inspire ideas.Yeah I probably should have but this one was cool looking, and the other was ugly, if similarly made. and I agree likely used in pairs.
I was thinking maybe for meat, before health codes, but no sign of blood on the seizing
When replacing a damaged or broken bit, I cut a shallow groove in the replacement for the grub screw to engage. This allows a little play, but won't let the bit fall out of the socket.BINGO! (applies dope-slap to self)
Why didn't I think of that? I have a set of Allen sockets w/replaceable shanks somewhere around here....
This makes decent sense, less blood to soak in, and on boat handling is, or maybe was, less suspect for contamination Id think.Very similar to hooks used to handle fish in commercial fishing applications.
Does it smell of fish?This makes decent sense, less blood to soak in, and on boat handling is, or maybe was, less suspect for contamination Id think.
Another likely idea, not common on the west coast, but things travel.It looks like tools used in the north to pull chainsaw cut blocks of river/lake ice out of the hole.
I'm sure this double-bit driver came in some kind of vehicle road tool kit, but can't for the life of me recall which one:
No markings. The bit is 8 1/4" long and was originally some sort of silverish plating (galv, most likely), then rust, then cleaned to bare metal.
Any ideas what it came with? I've owned a fair few Japanese vehicles and I'm leaning that direction.
Possible! I've owned a lot of VWs, too.The old VW Beetles had something like that.
Dad's new '71 had a small tool pouch with a few tools, pretty sure there was one of those in it.
Hoof pick.
I meant the use case shown. A hoof pick is what you use for cleaning hoofs, regardless what the manufacturer intended it to be used for.cotter pin tool.
Proto part number is J2306
Wilde 544Z
Handy for all kinds of stuff. Every tool box should have one. Even if you don't own a horse.
But that isn't what Outlaw has. His would rip the **** out of the frog and leave you a crippled horse.
Believe it or not, I know that, and I'm not even a farrier. "Hoof parers" appear in old catalog listings.
